Guest Dylan Dude Posted June 29, 2007 Report Posted June 29, 2007 I don't get the box. What are you doing?
LSN2meBoom916 Posted June 29, 2007 Author Report Posted June 29, 2007 I don't get the box. What are you doing? HAHAHHAHA. I'm building a rattle free trunk silly! The inner box (with the 3 holes cut for the subs is the airspace they will play in like a normal box. The outer enclosure is to trap all the bass and keep it from pressurizing the trunk and rattling it to hell. Think "bandpass box without the ports" (hopefully a similar effect of the air/sound waves getting channelled around the outside of the inner enclosure. After I chop the vertical walls and bring the top down a bit, the "channels" or air passgae around the outside of the inner box will be around 15" high and 2" wide. That's 30in^2 of "port area" on each side plus the TOP channel which will be around 36" wide and an inch or 2 high (at least another 36in^2 of "port area" Thus, if any of the same rules applyconsidering port area/airspace ratio in terms of ported boxes,I should be sittin pretty with at least 96"^2 of "port area to channel air into the vehicle-PLUS, it will have a vertical "chimney" opened up to relieve pressure through the rear deck, directly above the top of the outer enclosure too. Mind you-these are NOT ports. Just open area for air to move into the cabin and it will all exit the back/open side of the outer enclosure and the rear deck "mouth". Hopefully=loud in car and ZERO RATTLES. If you look at the pic that shows the rear seat side of the box^^^, it's OPEN. Thus, all the sound the subs are making will be funneled into the cabin of the car and you will have little or no trunk rattle. It's a box inside a box with the "mouth" (kinda like a reverse horn but hopefulyy not THAT effect) and all the bass will be IN CAR rather than in the trunk. That's what I'm doin. Make more sense now? COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
andym85 Posted June 29, 2007 Report Posted June 29, 2007 ahh..never looked at it like that. so basically the subs kinda load off the back of the trunk (where the license plate is) and the sound waves get funneled through the channels of the larger box back into the cabin? i like it... i likes me some audio stuff...
LSN2meBoom916 Posted June 29, 2007 Author Report Posted June 29, 2007 ahh..never looked at it like that. so basically the subs kinda load off the back of the trunk (where the license plate is) and the sound waves get funneled through the channels of the larger box back into the cabin? i like it... Correct...Kinda. The Idea here is to KEEP the subs from loading off the inside walls of the trunk. Instead, the whole front of the box thats facing the back wall of the trunk (rear end really) will be SEALED OFF via another piece of mdf that spans the length of the box and has a large oval plexi viewing window in the center so you can watch the subs moving thru the glass. The INNER enclosure will of course get white vinyled and then lights inside the outer enclosure will light it up and be wired to the trunk light. THIS WILL BE VERY MUCH LIKE A BANDPASS-but no "ports" just those air channels around and over the top ove the inner box. COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
andym85 Posted June 29, 2007 Report Posted June 29, 2007 oh, ok...i wasnt aware u were sealing the front of the box off...makes perfect sense now... i likes me some audio stuff...
LSN2meBoom916 Posted July 10, 2007 Author Report Posted July 10, 2007 Sorry again folks! I know it looks like I been sleepin on this one but I've just been havin some PC issues and couldn't get the pix up for ya so here's the latest updates. I measured/chopped down the sides of the outer enclosure so it'll fit in the trunk height-wise. Top sits a lil lower now. So after the outer shell was all put together..the only way to get it into the trunk was to divide into 2 pieces so I had to slaice it down the middle and figure out a new "sealing" method" The sides ended up catching on the lift arms for the trunk lid so I had to re-work the edges a bit too. view into the cabin through trunk with no box in.(Notice the shiney strut bar) COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
LSN2meBoom916 Posted July 10, 2007 Author Report Posted July 10, 2007 So after the box stuff was pretty much figured out I got busy on the rear deck cut through. There's actually a nice lil (10"x6") opening in the rear deck so I just copied it and cut through the soft parts. Hooray for no sheet metal there. Makin my lil chimney DUCT TAPE= "The Poor man's angle clamps". Held it fine while I threw screws in it. Hangin through the rear deck BEFORE- AFTER- COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
LSN2meBoom916 Posted July 10, 2007 Author Report Posted July 10, 2007 The opening here WILL get prettied up-and look pretty close to factory If i can swing it. Bck to the outer enclosure- That lil chimney needs to "seal" and attach to the top of the outer enclosure and breath through so here's the openings I made. COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
LSN2meBoom916 Posted July 10, 2007 Author Report Posted July 10, 2007 Now-here's some lil 1.5" spacers I made up real quick. They are temporary-I will make a beveled set to let the top sit correctly later. They are to hold the top piece of the outer shell UP level so it doesn't sag once it gets cut in half-just like the bottom board. In the end the outer shell is 2 side pieces (via the slice down the middle) and the front face attaches to seal the trunk off. They go right here You can kinda see the left spacer in ther holding up the top piece on the left side. And as I said-Not sitting level until I bevel those spacers. Other spacer+top piece Front baffle-this piece is the SEALER for the outer enclosure and will go on last. It's gonna have a nice big OVAL cut in it and plexi to fill that oval. The interior gets white vinyled and blue neon. Here I finally cut some lil notches for the hood arms/lifts but I dunno if it will look like that I'm playing with some other ideas. Front baffle folded down just to check some clearances. View with seats down so far.. Deck opening Think that's it till wednesday at the earliest, that's my next day off to hit it up but I DO have wed-thurs-fri to play with it so maybe I'll have some cool pics by friday. Whatcha guys think so far? COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
jasonw30 Posted July 10, 2007 Report Posted July 10, 2007 starting to come together.looks good. 2002 nissan frontier crewcab eclipse cd2000 mb quart prem's fr&rear rf p4004
