Rebuilding my box soon. Wanted to know some good sealing ideas. Also, would any bracing be needed? Thanks
06 Police TahoeHU- Pioneer 80prsAmp- Crossfire 8kSub- 4 15" Crossfire xs v2sWire- 1/0 Knu/AudiotechnixAlt- 3 Mechman SMD 340sBatts- 6 XS Power 3100s, 2400
use a wood glue like tight bond or gorilla glue when ur putting it together. then use fiberglass resin on all of the seams
MY TRUCK BUILD - 1976 F-100 Ranger. Fully built 482 big block, 4 DC lvl4 15's in a blowthrough, plenty of custom fabrication.
MY HATCH BUILD - 1993 Honda Civic DX Hatchback . Clean daily driver, dropped, subtle customization.
and it all depends on what you are doing to decide if u need bracing. a lot of people use wooden dowels or all-thread
use tightbond over gorilla glue. Silicone caulk the edges and or fiberglass resin
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
yea i agree about the glue, just throwin some names around.
Yea silicone was my first thought. Any specific order in which I should apply these?
well use the wood glue when ur putting it together then before you put the baffle on use the silicone and spread it on all of the seams to make it as air tight as possible. then the fiberglass resin over that.
Would it still be pretty airtight if I didn't use the fiberglass resin? or is it a must
yea thats just an extra precaution you dont have to. just the better sealed the seams are the better off. but no u don't have to use the resin.
I've heard of people spraying something over the entire inside to help keep the mdf nice and strong. any ideas as to what it is and if it would be worth it?
So just put some tightbond over the seams and let it dry. Before we put the top on, put some silicone over all the seams and such. What should be applied to the top? Same thing?
  • Who's Online   0 Members, 0 Anonymous, 2422 Guests (See full list)
