ive wanted a crapolla or something to do exactly this with <.<
that aside, good luck man, and make sure to file down all those sharp corners, dont want an accident! my cousin was cutting up his truck for a blowthrough, hit his arm just right when he slipped, and ended up loosing like a quart of blood. stuff was pretty bonkers....
but what kind of sub and amp you using bro?
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
who here has good designs and is good at round ports?
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
I will make sure that I do that cause I don't want blood all over my car!!!! I am running a Kicker L7 15" 2 ohm with a power acoustik bamf 2000d. hopefully will get a rockford fosgate t1000bd soon!
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
no one knows tube ports :cray:
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
I wish I had your trunk, look at all that height! Why not do some slot ports forward out of MDF. Aero ports are for lazy people and number farters :D (I'm prolly startin a fight :aggressive: ) I never use aero ports unless the customer brings them too me. I would consider them, but damn they are expensive, MDF is much cheaper and the results are just as good, if not better depending on skill level. I wish I would have taken more pics because I am missing a lot of how to's that would have helped you. Good luck on the build, I'm def tuned!
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
Thanks CC, That means a lot comming from you. I just need to find someone on here to draw me up a plan. I hopefully willo get a 15" bl within a year or 2 or maybe the 18". The L7 will hold me over for now.
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Your building into a trunk, no one will be able to draw you a plan that will actually be able to help you. You need an idea in your head and basically wing it as you go, but always think way ahead. I ran into atleast 2 dozen problems and my original idea was completely scrapped by the end of it, but thats how in trunk builds go when your desperate for airspace. Start with the floor, and then check height clearances with the trunk closed to find your outline on your trunk floor, then you can get an idea of potential airspace. Ideas will come you as you build and brace the shit out of everything. Fiberglass is your friend for multiple angled sides. I used to have a 12" Solo X so I am an ex-kicker guy now.
It's all gone!
The Celica Build
Feedback
the thing is if I fiberglass my trunk I can't get it out to sand or anything. For now I just want a box that goes from the opening to the back for the trunk. That isn't too hard to build. I will work my way up with glassing when I do my rear deck.
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
if you have the same trunk space as me a btl could fit back there with a slid in box. if you of course cut out the metal thats in the way.
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
yeah I am gonna cut it. right now just the 15 but I need an enclosure guy here!!!
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   0 Members, 0 Anonymous, 607 Guests (See full list)
