zaxfire69 Posted April 18, 2007 Report Posted April 18, 2007 Hello. My father has a Gmc Jimmy with the bose audio system and he is wanting to upgrade his stock radio to an aftermarket unit. How would he go about doing it and can he do it..He wants one like a Sony or a Pioneer Cd Deck that plays Wmp, Mp3 discs...Tell us what all we would have to purchase to do this...?? Thanks in advance.. Quote
AlpineGuy87 Posted April 18, 2007 Report Posted April 18, 2007 just as other head unit upgrades.. should have no problems really.. bose speakesr and such shuold be able to hook up to any head unit... thats my guess.. I mean, its been done.. my buddy gots bose speakers and he has a new headunit in there.. shouldnt be any problems man.. Quote 06 SCION tC
Eddy722 Posted April 18, 2007 Report Posted April 18, 2007 Buy the harness for that car. Please don't cut the factory harness. Crutchfield should have everything you need. Just put in the vehicle model and year. Quote
AlpineGuy87 Posted April 18, 2007 Report Posted April 18, 2007 Buy the harness for that car. Please don't cut the factory harness. Crutchfield should have everything you need. Just put in the vehicle model and year. yea you'll need the harness to hookup an aftermarket headunit and thats pretty much all you'z got to do man!! Quote 06 SCION tC
SPLGEO Posted April 18, 2007 Report Posted April 18, 2007 WRONG sorry waite... bose systems are amped systems, more then likey there is an amp on each speaker that you must bypass the amp, or else you'll run into BIG problems.... just run new wire to each speaker from the radio Quote 1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
AlpineGuy87 Posted April 18, 2007 Report Posted April 18, 2007 really... you mean you cant even use the amps... like can you just use the speaker wires that the old unit used.. i figured you just be able to take old connections and put them into the new head unit.. so like.. you cant use the amps on the bose speakers? or .. idk maybe im confused.. lol Quote 06 SCION tC
mojoman Posted April 18, 2007 Report Posted April 18, 2007 with the bose system, you can run the standard 1858 wire harness. if you keep factory wiring, you will need to power up the pink wire in the 9 pin flat connector behind radio with 12volts accessory. this will power up the bose amps. if you have on-star then you would need a 72-006 harness. (metra harness numbers) there is no need to run wires to each speaker. i am assuming your jimmy is 2001 or earlier though, if it is newer it might be different. Quote
roscoe1129 Posted April 18, 2007 Report Posted April 18, 2007 on my 04 burban w/ bose i had to get a PAC adaapter that let me use the bose amp with my eclipse head unit. the adapter was like 100.00 to purchase. Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
SPLGEO Posted April 18, 2007 Report Posted April 18, 2007 (edited) yaa... turn but wouldn't it be easyer to run new speaker wires, instead of pulling out 100 for the harness o and yes if your jimmy is 1990+ you'll need that nice harness, so that your trans won't burn up, and your air bags will go off Edited April 18, 2007 by SPLGEO Quote 1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
Chode69 Posted April 18, 2007 Report Posted April 18, 2007 WRONG sorry waite... bose systems are amped systems, more then likey there is an amp on each speaker that you must bypass the amp, or else you'll run into BIG problems.... just run new wire to each speaker from the radio CORRECT!!! you MUST bypass or you will be putting an amplified signal into an amp and it will make it sounds liek shit. Quote NoFearX18 said: Nick will bang just about anything.....LMAO....pun intended On 4/13/2010 at 9:51 AM, meade916 said: i was like DAMN, Chode is hardcore! he makes james look like a friendly person LOL! trainman0978 said: I dont know who is worse with the buttholes Chode or Big P... Team Deadly Hertz / Team DC Audio / Team XS Power 2010 DC AUDIO MEMBER OF THE YEAR!!! DuckretaryFEAR THE DUCK Durangho Chodes Blowthrough Build Youtube vids Muh Wife Need DC Audio? Hit me up for pricing!!!
