1ohm Load
Do you have the dual 2ohm coils or the dual 4ohm coils?
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
http://rockfordfosgate.com/rftech/woofer_wizard.asp
this MAY help...also do you have the full size pic of the pic in your sig...if so hit me up in a PM and ill give you my e-mail address because i wanna print that out and put it in my vehicle
NoFearX18 said:
trainman0978 said:
Then you can't do it, unless you wire each coil to an amp or something. Then each amp would see 1 ohm.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
yep
If you wired 2-1 Ohm coils together ++ -- You would get a 1/2 ohm load right???
correct...and thats called wireing them in parallel
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 965 Guests (See full list)
