thanks guys :)
as of now, with the way things are going it should be donevery soon. my goal from the start was three days, and well today is day 3...soooo we'll see how it goes. as of now, i have completed the hardest stages of the build and all thats really left is to make the inner port wall...put the sub in...cut the top peice and figure out how to mount my amp so i can access it later on. the amp will be on the right side, but i want to be able to pull it up if nessesary...
i did a dry fit of the sub in the mounting hole. it works nicely. i drove to school and back and it didnt shift at all, even with the bolts not done up tight
Posted Image
i just finished putting the outer port wall on
Posted Image
Posted Image
i have to go to class now, but i will by right back here in an hour or so working on it..so expect an update in a couple hours
the hole that you cut for the wire....you just put electrical tape over it?
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
  • Who's Online   2 Members, 0 Anonymous, 787 Guests (See full list)
