doughboi916 Posted April 19, 2007 Report Posted April 19, 2007 i just built a ported box, im planing on mounting it rite in the middle, does it matter? i see alot of people mount ther subs rite next to the port or the the opposite side???
sean 371 Posted April 20, 2007 Report Posted April 20, 2007 You just have to look at the way the air will flow. If you have a slot port that curves and goes a fair way into the box, it makes sense to mount the sub adjacent to the port opening, so that all the air will be pushed towards the port opening. How you design the air flow will affect the sound of the box, but not by a huge noticeable amount (usually) A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
doughboi916 Posted April 20, 2007 Author Report Posted April 20, 2007 i planned on mounting it rite in the middle, will it effect anything?
sean 371 Posted April 20, 2007 Report Posted April 20, 2007 Mounting it over to the left would be the most efficient way. But my box is far from the most efficient design as well, as I didn't want to compromise the external looks for a little bit of sound quality/SPL gain. Edit: putting a horizontal 45 in the below where the sub will be mounted, and 3 vertical 45's (the two on the right side and the third in the port angle) will also help. A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
Slinky Posted April 20, 2007 Report Posted April 20, 2007 x2 on 45'in your corners. DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
