My Build Log for Nick from ROE 153.2 45hz
got a bit done. keep in mind this is not gonna be completely finished and made pretty by me. so the way it is pretty much is the way you are gonna see it at sbn and untill nick decides to go to town sanding and filling and everything to make it all pretty. i told him i would build the base for him and he could make it pretty after i was finished.
another layer of resin on the doors
this is how i keep the inside warm in order for the resin and paint to dry fast :)
wrapped the pillars and resined them and painted a couple coats on the baffle. had a little run above the point but o well haha.
well everything is hooked up and working. got the mids/highs tuned. have not messed with the subs because its too late at night to do it. but im happy so far. still have hours i could sit and tune the mids and highs but i think ive got them close. i took a vid of the mids and highs but i think i had my hand over the mic with the flashlight in my hand so it sounds kinda muffled. for some reason there is some rediculous turn off pop/squelch im not exactly sure what is causing it but im not a big fan of this eclipse dvd navi headunit. does not have enough adjustments for things.
doors before we put them back on. they are not getting finished by me but they will do for now.
so i got the subs loaded and hooked up and dropped the carpet and everything in.
ok the vid
this build is friggen nuts dude, craziest cav i have seen next to my buddies 01, turbo'd with nitrous and lambo doors. He finally sold the stupid thing
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
Nice man! the yellow is screamin in a good way tho :good:
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
couple quick tests playin bass mekanik - bass mekanik. also played around with a few other songs and it was doing over 150 from 35hz to 55hz. i was doing the same number at 44hz and 52hz from 2 songs i played. :) this thing plays 30hz like there is no tomorrow. cant wait to let nick show this thing off at sbn. ill get vids sometime this weekend probably. hope nick comes by and checks my masterpiece out :)
sealed on dash on bass mekanik
drivers door open on bass mekanik
still havent charged the batteries and been beating on the subs alld ay i decided to put the meter on it again :)
30hz :)
45hz :)
there is an EASY 154 in this once we get some things tuned in and a better headunit.
