I work at a company that does alot of printing. The big rolls of paper that we use have a 8" inner diameter cardboard tube in the middle. The walls of the tube are a little over 3/8 thick. They are very strong. I stood on the side of one while steadying myself to keep it from rolling and it didn't even leave a dent. My question is could this be used for a port? Any see any problems with this idea?
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
sure put it in and then coat with resin :)
it will not fail!
95 Civic Coupe
Pioneer AVH-P7600DVD
Kinetik HC-1200 In Front
Kinetik HC-2000 In Rear
Memphis 16-MCA3004
2 X Memphis 16-MCD1000 With Maxxsonics MLX-100
2 X DC LVL 4 XL 12's
Pioneer Premier TS-C720PRS In Door's
Kenwood KFC-6982ie In Rear Deck
All Memphis Wire/Rca's and misc.
Thanks guys. I was definitely planning on coating it in resin. Thinking of attaching a wooden trim panel to theends of it that would bolt to the box and making a few of the to have interchangeable ports. Always been curious about it so figured I'd give it a try. Any opinions on interchangeable ports?
cut a mdf ring to go around the outside edges and resin it to the ring ....
and then change out as needed
95 Civic Coupe
Memphis 16-MCA3004
How do I attach the trim panel to the box so that it will be removable? over time screws will eat the wood up.
some insert nuts and bolts will do the job..
i likes me some audio stuff...
are insert nuts like t nuts? I've heard people talk about them but never really seen how they work. I appreciate all the help.
Cool man. Those are pretty cool. I'll definitely use those. Thanks alot man I really appreciate it.
