actually what does the processor put out?  That would be what you needed to look at to decide on a line driver.  My Avic N1 only puts out 2v but my 3sixty.2's put out 5v which is PLENTY.    ;D
Follow my Tweet (Twitter)
The Clarion has 7 volt RCA outputs or whatever.
I really don't understand the pre-out thing. I've heard numerous people say that 5 volt is better than 2. I just don't understand what the significance with Pre Out Voltage is. Care to explain please? Anyone?
Guest 90accordman
from what i understand the higher your preout voltage the less gain youll have to run on amps, therefore the amp doesnt work as hard.  Also a higher voltage helps with noise that goes through the lines.
my audiocontrol does 7 voltrms. my gain on my amp is only up a tap. now and never even gets warm, might i add that i have a hifonics 1500d. the sound is so much cleaner and clearer.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Thank you for the replies and useful knowledge. Will really help when it comes time to order some things.
I think I'll start off with the Head Unit, Equilizer and 5.1 Channel Surround. Is there anything else I should really need to start with? My major problem is going to be getting it mounted in the dash, but I'm willing to cut it apart. Steve or anyone, if yall know of any good tutorials for cutting a dash apart to accomodate more stuff, please link me. I'm sure cutting it won't be the problem, it'll be making it look good again :D
what sort of equalizer are you talking about. the Audiocontrol 3.1 is a equalizer, crossover and line driver all in one.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Guest 90accordman
go with fi btl over re mx
he's not looking for an SPL system...Have you heard an RE MX?
