GOt a dumb question here for you guys!
I got a good question here. My subs are dual 4 ohm and I wired them up to the amp so that the amp was at a one ohm load. Heres the specs on my amp:
Amplifier Specifications
Number of Channels 1 - Mono
RMS Power (4 ohms) 300 watts x 1 channel
RMS Power (2 ohms) 450 watts x 1 channel
RMS Power (1 ohm) 600 watts x 1 channel
Bridged RMS Power Not Bridgeable
Total RMS Power Output 600 watts
Peak Power Output N/A
Minimum Impedance Unbridged 1 ohm
So my question is am I pushing 450 watts into my subs or 600? I just read a post that a dual 4 ohm sub can be wired at 2 or 8 ohm's. Thanks!
Kenwood Excelon KDX-693 Head Unit
Kinetik HC600
Powerbass 6.75's in front doors
Powerbass 6.75's in rear deck
Powerbass 1000.1D
Powerbass 400.4
2 SA-12 inch Sundown Audio Subs
0 gauge Power Wire and Big 3
Custom Amp Rack
Code Alarm with remote start
Stinger Digital Volt Meter
My build log http://www.stevemeadedesigns.com/board/topic/51869-1996-chevy-blazer-build/
My youtube channel http://www.youtube.com/user/kanesdisciple
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
AudioControl Epicenter
US Amps AX2000
US Amps MD-43
1 set Alpine type X components
1 set RF Power components
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
Kinetic HC-600 (Back)
Second Skin Damplifier Pro
Well how many subs do you have?
If you have two, then you can only wire them to 1ohm or 4ohms.
So you're getting 600rms.
Here's a site that'll help:
http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=4
Follow that link.
EDIT: The link is fixed for a 2 dual 4ohm sub setup. You can change that though.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
hmm...why ask if you know you wired it to a one ohm load?
unless you arent sure you wired it right
I got two subs and I always thought it was 600 going to them, but when I read that it kinda freaked me out lol. So between the two subs there is 8 ohms total and when I run a pos and a neg to the amp it goes to a one ohm load. Thanks for the reassurance guys!
Kinetik HC600
Powerbass 1000.1D
Powerbass 400.4
Custom Amp Rack
wiring 1 dual 4 ohm sub can be wired down to 2 ohms. add another dual 4 ohm sub in parallel and you can wire it down to 1 ohm (which is what you did) and just so you know in case you may be thinking differently, each sub is getting 300 watts
Yes I did know that but ty anyways!
Kinetik HC600
Powerbass 1000.1D
Powerbass 400.4
Custom Amp Rack
  • Who's Online   0 Members, 0 Anonymous, 957 Guests (See full list)
