so generally speaking... what would make a woofer bottom out at high volumes? an enclosure that is too large or an enclosure that is too small?
and just to get it out of the way... say that the woofer is being underpowered by atleast 25wrms and no clipping.... and is in a sealed enclosure...
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
well generally a woofer would bottom out if it has too much power thrown to it, too big of an enclosure, and playing under box tuning (doesnt apply to you in this case)
how big of a sealed box are you using?
well in my case it is my enclosure for 4 re audio rex8's.... the enclosure is somewhere between 1.2-1.5 cubes.... im not really sure since the bottom of the box is a mold of the floor of my truck....the specs on the woofers require .3 to .35cuft per woofer..... the woofers are rated for 175rms each and im giving them around 150ish after impedance rise each.... and they like to bottom out at 30-40hz..... ive put a little over a pound of polyfill in the box to help... and it has to a point....
3 Kinetik Hc2000's
Dual 200amp alts.
try putting something in the box like a block of wood or something ot take up some airspace (about.5cubes) and see if it still does it. this may help if your box is too big. if it doesnt you may have too much power
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
anyone heard of an underpowered sub bottoming out from too small of a space?
3 Kinetik Hc2000's
Dual 200amp alts.
nope you dont bottom out from being in a small area. bottoming out happens when the sub has too much excursion caused by either too much power or not enough pressure inside of the box(caused by it being too small)
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
i suppose i may have to try that... i just hate the idea of putting a brick in my subwoofer box... dont ask me why... i have no clue... perhaps im just ocd or something...lol
3 Kinetik Hc2000's
Dual 200amp alts.
Im going through the same thing. my box is too big & my surrounds are buckling when they hit real hard on the low notes. So a smaller box is in the works. Poly fill killed the sound of my box completely. & it sounds like you have way too much in there. 1 pound?
Current System:
Pioneer 6900 HU
Front Stage: (for now)
Soundstream tarantula 5.25 in the doors
Soundstream tarantula 4x6 in the dash
Kenwood 400.4 for mids & highs
Bass:
4 Soundstream RW-12's
2 Power Acoustik Stax 4000/1D's
single chamber box, 2.65 cubes.
Currently under the knife being bagged
Rebuilding err'thang
  • Who's Online   1 Member, 0 Anonymous, 1101 Guests (See full list)
