Hey guys! Well, I finally built a box on my own. it is not pretty, but then pretty doesn't always add db's. It is 4.13 cubes before displacement and 3. something after displacement. I still have a lot to do inside the box, but it did quite well without any improvements done to it yet. In initial testing, I was able to do 149.19db and at the show I did 149.2. I could probably do better with fully charged batteries. Not too bad for a small box. I have some pics. Tell me what you think.
Lookin pretty good man. Thats a BIG ass port. Those 12's or 15's?
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
Thats a crazy looking box! But, it seems to get them numbers, guess thats all that matters.
Alpine CDA-9847 HU
F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels
R Highs Infinity Ref. 9622i powered by HU
3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D
Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
are you running the subs on the same amp?
if not the phase should be adjusted on one of the woofers
defiantly interesting....... did you try both woofers up and port to the side?
and 49@ what hz?
Roseville, CA
and 49@ what hz?
Yes, both subs are running on a Sundown SAZ 3000D. I haven't tried subs up and port to the side. I turned the box so the port is firing into the driver's side. I did a 149.2@55hz.
  • 1 month later...
Here is a little update to my new box. My sub started sounding funny and found out that the top sub had blown the rubber gasket out from under the sub basket and several screws were loose. I checked the sub and it is fine. I ended up re-tightening the screws and putting tape around the sub basket. I ended up doing a 149.6 sealed on the dash with the term lab at 55hz.
Hey man, Thats a great number for what you have done so far !! Keep the great work. Just keep testing. If you need any help... let me know. :friends:
Edited by Db Linc Pres
2008 DB DRAG ROOKIE OF THE YEAR !
2008 DB DRAG COMPETITOR OF THE YEAR, 2nd
2008 World Finals ss 3-4 4th in regionals
2008 Highest Score 161.53 in a sedan !!!
2009 Best of Show,@ The Maxxsonics Show
Now 2- RE-MTs 18's
159.7 db @ Dash, 168.8 in Enclosure
8- Kinetik 16v
8- Sundown Saz1500d amplifiers
1- Jl Audio 300/4
1- Audio Control Overdrive
Two ton chevy SPRINGS> LOL
Pro Comp midrange drivers(Rep)
Team Db Linc ( Owner ) Teams still STRONG !! 2010
Team Kinetik and Rep
Team American Bass
Team Sundown
Have you tested it with the box turned aroung or caddy corner ? what was the score then ?
Now 2- RE-MTs 18's
8- Kinetik 16v
1- Jl Audio 300/4
Team American Bass
Team Sundown
