Cons of running subs in small enclosures
tristan560
So what are the cons of running a SSD 15 in 2-2.5 cubes after displacements. Ported off 1100w tuned to 35. Versus same sub in a 3-3.5 cube box.
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
Well ive noticed from my testing.. you get higher impedance rise in smaller enclosures
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
This is pretty much a common theme with smaller enclosures.
Pioneer AVIC-N2
The driver will take a hell of a lot more power to get even semi-loud ( I see a 142-143db legal hard to get, esp out of a trunk).
The driver will not unload the best due to the small non efficient box. Your speaker would need close to double its rms to get kinda loud roughly.
I really wanna get rid of my wall. It's the system in my sig. 4 15s off about 5k. But my max dim are 38.5x20x28.
Systemless.
I'm just worried about loosing low end output.
Well, consider it gone.
It will sound no where near your 4 15s walled.
Im assuming your just going to build a box for all 4 15s then?
IMO You would be better off taking that 5krms you got, and build 1 decent box for the 2 15s, and keep the other 2 for spairs or sell them.
It is fact that a 10 inch driver will outperform a 12 inch driver if the 12 inch driver is confined too to small of a space. (using the same power, vehicle box, etc).
  • Who's Online   0 Members, 0 Anonymous, 2631 Guests (See full list)
