Viper 5901 and 98 silverado
Ok guys what modules am I looking at for this? Pretty simple for now. Remote start and the door lock module is all I'm after at this point? Anyone know the part numbers or a place to find them? I havent done an alarm since I did it for CC and I just had the book to find the right pieces. Any of you shop guys able to help out? I'm assuming the door lock is the 451m but what is the bypass for remote start? Is there an all in one for this like the late model cars? Thanks in advance.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
PLJX is the newer directed bypass you will want. An old 555L will work if you can find one.
If it has keyless entry then it is positive doorlocks... if not 5wire.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
it has keyless I'm not afraid of a five wire anyways lol. does it require the 451m for the doorlocks? I think I have a 555l downstairs actually.....
Is there anyplace available to get a good tech sheet on these? I know all about testing first but some of the info out there I don't trust.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
real ez most of the wires is found in the bcm
ROCKFORD FOSGATE
OPTIMA BATTERIES
KENWOOD
DC POWER 270XP
2 18" MAYHEMS
5901 will do positive doorlocks... no 451m required...
and directwire:
1998 Chevrolet Silverado DirectWire 2.0 Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts red + ignition harness
Second 12 Volts
Starter yellow or purple + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition white + ignition harness
To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition pink/white + ignition harness
The pink/white does not exist on all models.
Accessory orange + ignition harness
Second Accessory
Third Accessory N/A
Keysense
Data Bus yellow (resistor code), orange/black (ground) Passlock 2 Passlock sensor on ignition key cylinder
Can Bus High
Can Bus Low
Can Bus Sw purple data data link connector under driver dash, pin 2
Power Lock lt. blue either door boot
5 wire (type C) on the two door models, and positive trigger (type A) on the four door and keyless entry models.
Power Unlock white either door boot
Lock Motor gray drivers kick panel
Driver Unlock Motor tan drivers kick panel
Passenger Unlock Motor tan passengers kick panel
Parking Lights (-)
Parking Lights (+) brown switch or fuse panel
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight yellow + at switch
AutoLights
Reverse Light
Left Front Door Trigger purple - light switch
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision
Trunk/Hatch Pin
Rear Glass Pin
Hood Pin
Trunk/Hatch Release
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)
Power Sliding Door (Right)
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Trunk Alarm Shunt
Tachometer white AC ECM
Tach wire on the 6.5 Diesel is white at the instrument cluster. ECM located on drivers side inner fender well. Two plugs, white wire in plug marked white.
Wait to Start dk. blue - instrument cluster
See Tech Doc 1090.
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense
Brake Wire white + at brake pedal switch
Parking Brake
Horn Trigger black - at column
Wipers purple + steering column
Left Front Window (Up/Down) dk. blue - brown A at drivers door switch
Right Front Window (Up/Down) light blue - tan A drivers door or boot
Left Rear Window (Up/Down) green - purple A drivers door or boot
Right Rear Window (Up/Down) lt. grn - pur/wht A drivers door or boot
Kenwood eXcelon 995
99 is when everything is at the BCM, not 98.
Kenwood eXcelon 995
Im not worried about the install part at all. Im experienced in alarms and I don't have to rush this one bit . I have a daily car this is my play toy. I can tear it all apart and leave it that way if I want.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
