ok as i said b4 that when i would turn my system up really loud an it would wang an just go into protect an turn off an i never had clipping either well i did go an re wire my subs to what the12vol.com said this
http://www.the12volt.com/12voltimages/2_1ohm_dvc_1ohm.gif
well now it dont turn off ne more but when i start wanging my lights dim an my dash lights dim an it shows im clipping on the amp some advice would be great bc it wasnt doing this b4
kia spectra 4 door
HU-a kenwood kdc-692x
optima red top under the hood ( kinetik battery or powermaster in the back )
Iraggi 260amp H/O alternator
1 set of knu kandy 1/0 guage wiring kit ( 2 more sets coming )
front speakers -
back speakers -
2 12" lv 4's with lvl 5 softparts ( going to be 4 in near future)
Sundown 3500d( going to be 2 sometime )
i have boughten from - Bass14(smd), ddbump(caraudioclassifieds)
turn the gain dowm.. voltage drop?
on the amp the gain is all the way at 0 the bass boost is all the way up an the ssf an lpf are at 10 o'colck so i take it since i have them wired up the right way now maybe this is what its supposed to be doing
kia spectra 4 door
front speakers -
back speakers -
bass boost all the way down.. no bass boost.. adjust ur gain accordingly using NO BASS BOOST!!!
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
alright shall do that tomorrow when i make my second vid so it should be louder using the gain an not the bass boost
kia spectra 4 door
front speakers -
back speakers -
Bass boost can add clipping.
You should put your gain around half way, maybe 3/4s. And bass boost down.
Your lights may always dim depending on your electrical system. It isnt hurting it, just a bit annoying.
LPF at 10 o'clock is good but try turning your SSF all the way down, unless you hear your subs bottom out or distort alot.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
ok i did what u guys said to do an idk the way it was wired b4 i rewired them was alot louder bc i re wired them to the wiring diagram an i re set my gains an its not as loud ne more but i can turn the head unit up a lil higher now i dont get it
Edited by Austin175
kia spectra 4 door
front speakers -
back speakers -
it may not be as loud as it was before because your amp was prob set wrong (too high). it may seem "not as loud", but you settings are right and your equip will last longer. its better for your equip to last for years on the right settings than your equip clipping, burning, shorting, etc. on the wrong settings...
Team Bass-Hz
well the way we had them b4 it wasnt clipping t all but then i re wired them to how there supposed to be for a 1 ohm load an now if i set my gains a lil to high i get clipping an yes i love these an i told john i take care of them so i would rather have them last way longer so maybe ill give it some time an they will get louder over time
Edited by Austin175
kia spectra 4 door
front speakers -
back speakers -
