I don't think anyone knows what difference it makes, i sure don't. People luv to assume suff and really can't back up what they'er saying. Who really knows what a bass boast does, why even have it on the amp, if it's just gonna add distortion, heat, and clipping. Has anyone ever tested the effect of the bass boast, or are we going by what we've heard by word of mouth.
This is quite possibly the dumbest thing i have ever heard on the interwebz!
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
yea i never use the bass knob, if you set your gain right you should be good, and i guess you could edit your eq settings on your hu to fine tune to your liking, i do a lil bit, but as far as a knob goes, the only positives in my mind are like
if your need to quickly kill your subs ie:. cops-- but i mean the volume knob also does this -- if only a lil bit slower
or if your trying to pull a "meade" and surprise peeps with the bass during demos or something.
Edited by P4killer_
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
i love my bass knob...BUT its tuned into my amps...gains turned down...so that way when i have the bass knob all the way down..the bass is all the way down..when i crank it...all hell breaks loose. i pretty much have it tuned to where when i crank it...its set to make the amps run at their peak cleanly. so turning it down only makes it a lil more clean and bass drops off.
and to who said it hasnt been tested...hell i did some "tests" the other day...i had someone sit in my truck...i tricked them...bass knob all the way down..there like ok wheres the bass then BOOM...hell look at all steves videos...and people mentioning "THE KNOB" is that enough proof? quit typing just to see your own words unless you have something useful.
NoFearX18 said:
The single best thing i've seen in awhile, thank you for your contribution.
Pioneer AVIC-N2
Here is a video that elemental designs did a while back that shows what bass boost does on an O-scope
http://www.icixsound.com/iv/view_video.php...8ff95ccfa94cebd
That ^^ needs to be stickied. Perfect proof that bass boost is bad for the subs when used incorrectly.
Chode, I may do what you did (assuming my amp comes with a bass boost knob).
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
The bass knob I have goes in between the headunit and amps. That way I can turn all sub amps down at the same time. I don't think it adds distortion or anything as I tuned everything before adding the knob.
Could be wrong though.
Team Pinnacle / Team SouthEastSPL / Team SoundStream / Team GPI / GPI Sales Rep for Florida and Georgia
  • Who's Online   0 Members, 0 Anonymous, 745 Guests (See full list)
