It goes buy shank size so usually its a 1/4, or 1/2 it should say it somewhere on router
x2, or you can test fit a 1/4" drill bit in the shaft to se if it fits. more than likely it is a 1/4".
For ports - the biggest roundover you can get for your router!!! My router will only hold a 1/2" round over, but I set it a little deep and then sand down the notch it leaves. I end up with about a 5/8"-3/4" round over.
You can also add a plate against the inside end of the port and make a round over there. I cut 2 pieces of MDF and make a hole in one the O.D. of the pipe, then the hole the I.D of the pipe in the other with a round over on the edge. Glue them together, attach it to the pipe and you now have a flared port on both ends for very little $$$.
That is what I did to these:
Edited by bkolfo4
Current system:
Previous systems:
so is the actual size of the roundover bit is going to be 1/4 or is that the shaft on my router and i have a square port or a vent can i use the same method or do i use a up spiral up to cut the square then use a roundover. another thing how can cut square subs out.. u did circles i want mine just like dat but square
Edited by p.chang4
  • Who's Online   0 Members, 0 Anonymous, 339 Guests (See full list)
