i'm bout too install 4 15" kicker cvr's dual 4ohms 1000w max 500rms i'd like to only have one amp to run them if thats possible and try not to break the bank if you got any suggestions i mean i'm asking you guys because i don't understand the ohms deal that well get back at me
Best way to wire it would be @ 2ohms on something like a Kicker ZX2500.1. Will send 625w or so per woofer, but the amp is a lil bit pricey. Or always could snag an Audiopipe 3000D and just adjust the gains accordingly to not overpower the subs with the full 3k.
I believe it can be wired @ .5ohm also, if u just parallel the entire series of wiring(correct me if wrong i'm getting a lil bit too tired right now). Something like a Sundwon SAZ1500D or IA20.1 @ .5ohm would be perfect in that case.
Do u have the extra electrical to back up at least 2k daily??
Edited by Marlo Stanfield
Pioneer AVIC-N2
2 DAT 1000.1's :)
Powering 2 ohm loads is always easier with 2 small amps rather than 1 big one IMO
Otherwise Kicker 2500...
Or a 2-in-1-box amp like a AP3000D
Edited by Boon
10.x volts fo' life!
you mean the battery power? for 2k and i can wire these 4 to a 2 ohm load capability?
Yea things like an HO alt, big 3, extra batts, etc.... Don't quote me exactly(a lil drunk and tired right now) but I'm 99% sure they can be wired to 8,4,2,.5ohm final loads.
For 2k I'd suggest u at least have big 3, a nice underhood batt(ex. kinetik 1400 or so), and a big batt out back(Kinetik 2400, XS 3100, NSB90, etc). H/O alt isn't a necessity, but it would put alot of ease on the system as a whole.
Pioneer AVIC-N2
so i can run them on a 1000w kenwood with a 2ohm capability? if a wired it right until i got a upgrade
Yea you could, idk how much output you'll have with less than 250w per woofer. What amp exactly do u have?? I wouldn't suggest you buy a Kenwood amp if u don't already have one.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 2993 Guests (See full list)
