Most likely the plastic shroud around the fan you are talking about is to suck heat away from your processors heatsink.
It be a bad idea to cut it out....
Unless you want to burn up your processor that is.
My mom has a Gateway that is almost the same way..
But thats what you get for buying a prebuilt computer..
You sacrifice performance and money for a pos pc. :)
Hmmm... I'll definitely have to think about that. Thanks for the info.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
You never really get good airflow from a factory computer. I suggest possibly getting a cheap all steel case like this http://www.newegg.com/Product/Product.aspx...N82E16811121087 with high CFM fans. One intake and one out. Or you could go for a little bit more expensive; and get a better case like this http://www.newegg.com/Product/Product.aspx...N82E16811133086 Always rembember, that most of the fans you get from a case are not good CFM. The first case, isn't going to have good CFM fans anyway. The second, more expensive. I would buy the case, and then later decide if you need better fans or not.
Thanks for finding those for me, but those are desktop cases. I'm talking about laptops.
15.4" widescreen
What it does:
plastic is an alternative to metal. dell laptops are worse. I used to have to replace hard drives like 15 times a week because the cooling was so bad.
I have an Inspiron 1720 and use it hard...it has the best cooling of any laptop or computer I've ever seen. It never even gets slightly warm. Same goes for my sisters 1525 or whatever the number of hers is.
A vitrolic, megalomaniacal sadistic psychopath.
Oh my bad. I didn't even notice it said it was a v6000 lol. I never upgrade laptops, They aren't as fun as regular desktops ;P
Congratulations Ive worked in environments with the dells as a systems admin and I've replaced hard drives. mobos etc that have warped from heat caused by the thing.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
That ducting is CRUCIAL to keeping it cool. Don't fuck about with it. The clear tape is there to stop the RF shielding inside the case shorting out parts of your motherboard. Leave it there as well, unless you want your laptop to go kapow-fizz-smoke.
EDIT: I left the duct off an Asus laptop once and it would shut down from the CPU overheating before it could boot Windows.
Only a few bits of a laptop actually run hot... being the drive (if it's not an SSD) the CPU, GPU if it has a discrete one, and the chipset. Which will all be covered with that duct. Who cares about cooling the rest...
Edited by Boon
10.x volts fo' life!
the first thing i thought when i read the origional post is "wow, hes gonna cut that thing apart and destroy it"
leave it alone, all that ducting is there to duct air to where its needed and away from where its not. I'm not calling you dumb, but if you're somehow outsmarting an entire team of computer scientists and engineers, the world is in trouble. A mass produced laptop like that isnt some guy throwing a bunch of crap into a case and then copying it millions of times over, a lot of that stuff is custom designed and machined, and entire teams spend months or years developing every last little piece and testing it over and over again. if there is tape there, its there for a reason. if there's plastic there, it has a purpose. Theres not some guy puffing on the herb going "hey, we should make 900,000 of these little plastic duct thingys and just pop em in every laptop we make"
Team DC
  • Who's Online   0 Members, 0 Anonymous, 903 Guests (See full list)
