JacobHall103 Posted October 11, 2009 Report Share Posted October 11, 2009 Hey guys, my two 8's in a ported box on a ZX 300.1 Kicker Amp have been making this horrible noise it almost sounds like a fart, is the best way i can describe it. The box is right behind my seat in my 1990 Chevy. Ideas on how this problem was caused and how i can resolve it and is it serious? -Jacob Quote Link to comment Share on other sites More sharing options...
Andrew2944r Posted October 11, 2009 Report Share Posted October 11, 2009 If its a single cab, sub might be rubbing against something. Quote Team Ampere Audio Link to comment Share on other sites More sharing options...
JacobHall103 Posted October 11, 2009 Author Report Share Posted October 11, 2009 If its a single cab, sub might be rubbing against something. yea its a single cab, the seat is right up against the box and the subs i put some grills over the subs but it didn't help, same farting sound. Quote Link to comment Share on other sites More sharing options...
Marlo Stanfield Posted October 11, 2009 Report Share Posted October 11, 2009 If its a single cab, sub might be rubbing against something. First thing that came to mind. Quote 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
JacobHall103 Posted October 11, 2009 Author Report Share Posted October 11, 2009 First thing that came to mind. i guess if it was rubbing against something the only thing would be the seat, and like i said, i put grills over the subs to keep it off the seat and it didn't make a difference. Quote Link to comment Share on other sites More sharing options...
Andrew2944r Posted October 11, 2009 Report Share Posted October 11, 2009 Pull the seat fowards and see if you get the same sound Quote Team Ampere Audio Link to comment Share on other sites More sharing options...
JacobHall103 Posted October 11, 2009 Author Report Share Posted October 11, 2009 Pull the seat fowards and see if you get the same sound yea i tried that as well, didn't help, same sound...could this be a port problem? or is something wrong with the sub? Quote Link to comment Share on other sites More sharing options...
Skullz Posted October 11, 2009 Report Share Posted October 11, 2009 If you have a ported box place a hand over the ports and see if that stops it, if not pull the grills and lightly tug on the surrounds to see if they have broke free from the basket. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
JacobHall103 Posted October 11, 2009 Author Report Share Posted October 11, 2009 If you have a ported box place a hand over the ports and see if that stops it, if not pull the grills and lightly tug on the surrounds to see if they have broke free from the basket. thanks for the help but, just tried both those suggestions and neither worked the surrounds are still secure in place and putting my hand over the port doesn't make a difference, the horrible sound still exists... Quote Link to comment Share on other sites More sharing options...
Skullz Posted October 11, 2009 Report Share Posted October 11, 2009 Pull the subs and check the spiders or anything inside the box itself that could cause anything wierd. Like a plastic bag that may have been sucked in or something. Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
