OBI Posted October 13, 2009 Report Posted October 13, 2009 (edited) Got out my old ZX1500 and noticed something was moving around inside. This amp worked fine for over a year. Then I took it out and put it in closet(untouched). This a big deal? Little plastic piece broke. Piece Edited October 13, 2009 by OBI Quote
HHR Ed Posted October 13, 2009 Report Posted October 13, 2009 pic is fuzzy but looks to be a diode Quote Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
OBI Posted October 13, 2009 Author Report Posted October 13, 2009 Does it matter, if that little plastic piece covering the little metal bars, chipped off? Quote
HHR Ed Posted October 13, 2009 Report Posted October 13, 2009 yes it does matter. Is that the power supply portion of the amp? Could be having internal voltage/polarity problems. Quote Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
CaptainzPlanetz Posted October 13, 2009 Report Posted October 13, 2009 yes it does matter. Is that the power supply portion of the amp?Could be having internal voltage/polarity problems. I believe it is the Power Supply side, to the right or the little diode is the Battery Postitive connection terminal. Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
OBI Posted October 13, 2009 Author Report Posted October 13, 2009 Yea thats what it is. Here's where they were located at Quote
SPL2K Posted October 13, 2009 Report Posted October 13, 2009 (edited) yep....its a diode. eazy fix. Just make sure you get the band on the right end. Edited October 13, 2009 by SPL2K Quote Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
OBI Posted October 13, 2009 Author Report Posted October 13, 2009 yes it does matter. Is that the power supply portion of the amp?Could be having internal voltage/polarity problems. So this amp is bad? Thats wierd never had any problems with it. Quote
Boon Posted October 13, 2009 Report Posted October 13, 2009 (edited) Ever accidently hook it up backwards? Cracked diodes are ALWAYS bad, you're probably lucky and it blew 'open' rather than short. Usually around there they're used to shunt spikes in the power supply or to drain the caps in the amp when it's disconnected AFAIK. Pretty easy fix, make sure you replace them with an identical part, you'll probably need a good iron to get it hot enough to de-solder. Be careful removing it from the board, often helps to clip the part out then just de-solder the stumps of the legs... those diodes have pretty thick legs compared to the holes sometimes and the last thing you want is to mess up the pads/donuts. Can be indicitave of another problem in the amp though... Edited October 13, 2009 by Boon Quote 10.x volts fo' life!
OBI Posted October 13, 2009 Author Report Posted October 13, 2009 No man I never hooked it up backwards. Im not sure if I wanna attempt to replace it. I might mess something up. Seems easy in my head till Im actually doing it. Damn I wanted to sell this thing too. Quote
