BanginOnABudget Posted October 14, 2009 Report Posted October 14, 2009 do they make little charging relays?im working on an electric scooter and i need a lil 120vac to 12vdc charging relay, should i just addapt a wall charger or should i try and find a charging relay? and how does a mah work (ex: 500 mah) is 100 mah 1 amp? im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire. Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block.... 1990 Jeep Cherokee 2 Dr. Big-3 in 0g on Stock Alt. Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos. Pioneer 6000ub Reciever NO amps at the moment. SA-15 on 1kw coming soon. MSG Me for a free enclosure design!! Flared port kits coming soon!!
Boon Posted October 14, 2009 Report Posted October 14, 2009 1000mah is 1Ah - Don't forget the h. It's important. And 120vac to 12vdc charging relay? Eh? Since when did relays change voltage? Sorry, I'm confused here. 10.x volts fo' life!
Skullz Posted October 14, 2009 Report Posted October 14, 2009 DO NOT try to charge batteries with wall 12v transformers EVER. You risk blowing the battery, or even burning down a house trying something like that. I've seen what happens to over charged sub C batteries from guys racing and it isnt pretty or safe. Do yourself a favor and buy the correct charger and batteries. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
