12" 15" or 18"
sebasstian
So i am thinking very hard about what to buy to be the loudest. If you took subs from the same company same on every level but the sizes what would be losdest. 3(or 4) 12", 2 15" or 1 18". All wired down to same Ohm with same amp and specs.
12 RE audio X series 12's
4 gauge wiring to back batt (soon to be 0 gauge)
0 gauge from batt to amp
kinetik 1800 in back
clarion cx-200 HU
SPL 3000 wired at 2 ohms
8 Re 6.5 full range speakers
Re Xt 800.4 4 channel amplifier
Autopager car alarm
4 12's
Refs-(b.f.) 99vic, WCA Rusty(x3) Nathan@XSPOWER, Ampjunkielikeme, Bread0710, AmiCreations (s.t.) REsLaPz, PandaGT(x2), Keiferacing, Juicemane (t.w.) Powski, Big gil[/center]
Build Log
http://www.stevemeadedesigns.com/board/topic/77726-sss-celica-dc-buildupdate-611-finished/
2005 subi STi 380whp 355whp
17" gold bbs
5% tint all around w/sunglare strip
JVC dvd double din
Knuconceptz 4ga wiring
XS Power!
Big 3
8" SAv2 d2
1800 audiopipe
4 12's more cone area
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
4 12's , not only for the cone area, but if they were the same subs, they would have the same specs ( magnet weight motor etc, other than baskets n all that) so you would have ex 200 lbs of motor/mag instead of 50 lbs of motor/mag on 1 18. Get da 12's
^^ wut they said lol :P
the only person i wouldnt let build my box would be Ray.
Team Heavy-Flex4 SA 12's tuned to 29hz
Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
well 4 12's is more cone area... but what you have to take into account for is.....
if your running 1 18... i would assume you would only run a single amp.... what you need to remember is that the more resistors you hook up in a circuit the greater the impedance rise...
so if you hook up and 18 at 1ohm.. it dc resistance is going to be around .9
if you hook up 4 12's at 1ohm... the dc resistance will be a bit higher say around 1.3
then once you slap the woofer(s) in an enclosure you will get box rise... so your impedance will be a lil higher than that... and we all know higher impedances= less power
so in short(yeah i know its already long)... if you run a single amp i would go with fewer but bigger woofers... if you run multiple amps then i would go for the quantity option...
someone correct me if im wrong.....my .o2
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
  • Who's Online   0 Members, 0 Anonymous, 6701 Guests (See full list)
