Hi all,
Any guys know or using this amp??? pls review on this amp.Thank you.. :clapping::clapping::clapping:
http://www.theloudest.co.uk/?sectionid=2&a...p;product_id=91
Features:
Class D Monoblock Subwoofer Amplifier
Remote gain controller included in the package
Huge Power Output
Subsonic (20 ~ 50 Hz adjustable), Lowpass (40 ~ 180 Hz adjustable) and Bass Boost filters
N-Channel Circuit for high efficiency
Excessive heat, Reverse polarity, Short circuit and Input Overload protection
Heavy-Duty Power Supply
Heavy-duty aluminium heat sink
“Bass Kompressor” circuitry provides extra low-frequency enhancement
Specifications: Output Power (14.4v)
(When bridging the channels)
1 x 8,000 watts Max (@ 2 ohm)
1 x 3,000 watts RMS (@ 2 ohm THD+N < 3.5%)
1 x 2,000 watts RMS (@ 4 ohm THD+N < 2%)
Up to 1 x 3,400 watts RMS (@ 2 ohm)
Up to 1 x 2,500w watts RMS (@ 4 ohm)
(When using both channels individually)
2 x 4,000 watts Max (@ 1 ohm per channel)
2 x 1,500 watts RMS (@ 1 ohm per channel THD+N < 3%)
2 x 950 watts RMS (@ 2 ohm per channel THD+N < 2%)
2 x 600 watts RMS (@ 4 ohm per channel THD+N < 3%)
2 x 560 watts RMS (@ 4 ohm per channel THD+N < 1%)
Frequency response 10 Hz ~ 200 Hz
Subsonic Filter Frequency Range 20 ~ 50 Hz (Adjustable)
Low Pass Filter Frequency Range 40 ~ 180 Hz (Adjustable)
Bass Boost Frequency Range
45 Hz
Input Impedance
67 Kohm
Input sensitivity
0.2 V ~ 5 V
Signal/Noise Ratio (A. Wtg)
1 Watt Reff.
>100 dB
Damping Factor
(100 Hz @ 4 ohm)
>120
Efficiency
82%
Total Harmonic Distortion (THD)
4 ohm loaded 1 Watt 0.20%
800w RMS 0.50%
80% of total 0.70%
Idle Current 2.4 A
Max Peak Current
240 A
Minimum Subwoofer impedance Each channel individually
1 ohm
Minimum Subwoofer impedance when in bridge mode
2 ohm
Power supply
DC 12V
Dimensions
(length x width x height) 832 x 195 x 60 mm
Hi all,
Features:
Huge Power Output
45 Hz
Input Impedance
67 Kohm
Input sensitivity
0.2 V ~ 5 V
1 Watt Reff.
>100 dB
Damping Factor
(100 Hz @ 4 ohm)
>120
Efficiency
82%
800w RMS 0.50%
80% of total 0.70%
Idle Current 2.4 A
Max Peak Current
240 A
1 ohm
2 ohm
Power supply
DC 12V
Dimensions
The bold has me worried.
Plus:
According to the site, it has a 250 amp fuse included. It claims 8000 watts at 14.4 volts, but even at 100% efficiency at 14.4 volts at 250 amps, it would only do 3600 watts. At 80% efficiency it would do just over 2800 watts. It might do what it claims, but I highly doubt it.
Plus the THD is a little high. Most good, high quality amps of similar power have closer to 1% THD from what I've read.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
I have never heard of it, but from looking at the specs, it is 2 amps in one case, and the Distortion is higher than what I would normally like to see at rated power, so at 3K Rms it is at 3.5% I would normally not get a Class D amp that is above 1%.
¿ǝɯɐƃ ǝɥʇ
Its says it does 3000wrms (8000max which is irrelevant....)
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
I guess I was right about it being 2 amps in one case, Like the AP3000, Oh and this made me laugh in the link that the OP gave if you scroll down to the bottom that has the customer reviews some guys says he has the amp hooked to his Sonys LOL.
¿ǝɯɐƃ ǝɥʇ
it only claims to do up to 3400 watts not 8000......
I'd hit that so fucking hard whoever pulled me out would be King of England.
Lol... looks like we were on the same page. Car-B-Ques suck.
ya, tires and paint burning make the marshmallows taste funny.
The case and internal pics look very very familiar, can't quite remember to what though.
But that amp only does like 3k and the price tag is astronomical.
Pioneer AVIC-N2
looks like an older stetsom 6k or 7k type design. Those amps were kinda fragile. Its actually 2) 1500w amp boards side by side in one case.
Actually, thats like the older Hifonics Colossus design too. Which was a fantastic amp that did 3200w
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
  • Who's Online   0 Members, 0 Anonymous, 2372 Guests (See full list)
