Okay, so like I said in that other (played out) thread, I did finally figure out how to make my PC wake up from "Hibernate" at a time set by me (in the BIOS of my MB) then all my PC maintenance stuff to take care of itself, on a schedule set by me, then finally, to go back into hibernation on a timer (the one Logan recommended) set by me.
And it all works fine..... except for one thing... The timer only works once, then needs to be reset every single time I use it (everyday) ! Granted, it has a "load" button, and all it takes is one single click, but it's just a matter of remembering to do it, and if I can't make it an "automatic, everyday thing" I know I will forget to load it "often".
Is their an auto shutdown gadget that allows you to set a time, then click an "everyday" option ? Thank God their is an "everyday" option in my Bios, to wake the PC up from hibernate, because otherwise, having to go into BIOS everyday, would be such a bitch, it would not be worth it.
Anyway, the gadget I'm using is this top one that Logan showed....
Much thanks,
Fish
i have not been able to set it automatically, im not sure if there is one that does it or not...i dont use it daily, i use it every other day or less, i usually will put on pandora and then set it for a set amount of time to go off after im asleep...that 1 click refresh you mentioned is how i do it...ill keep an eye out for another one for ya
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
There's a built-in command that shuts down your PC... not sure if it still works on Vista but hey...
Open a command prompt and put in:
shutdown -s -t 0
For instant shutdown (-t specifies the timer in seconds)
Although that will shut the computer down, not hibernate it. If that works for you then you can create a cmd file with that line in it and schedule it with Windows Task Scheduler
10.x volts fo' life!
