cheap fiberglass resin? anyone know of any places? i dont wanna spend $50+ a gallon :o
still cheaper than ink or toner tho.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
I use Elmer Resin good stuff imo...doesn't jelly upon you if your heavy handed with hardener....only runs me $37 a gallon. Much better than that Bondo junk....
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Doesn't darvex sell it... Check boat supply stores, it's usually where I buy all my mat + resin in quantity at.
Pioneer AVIC-N2
