that box really isnt big enough to worry about bracing. its not like the xplods are going to flex a box much. if you do want to brace, a 1.5-2" dowel in the middle of the 39" piece would do you just fine.
screws are only for clamping pieces together while the glue drys. yes you leave them in after but you dont need very many as long as you have clamps.
Ok i was reading an article that said that i prolly wouldn't need bracing but i was just making sure from you pros.
also do i need to predrill the holes when doing the screwing into the board on top?
also what is the benifit of using resin in a box?
hopeful noob
im glad u figured out sketchup bro
nice design, lolz
give the subs as much space between each other as possible
i would put the bracing (1"+ dowel rods) front to back right where the lower and upper speaker meet on both sides
top to bottom right next to the rods going front to back... screw these together
then so side to side with 1 dowel... and screw the dowel to the two vertical dowels going from top to bottom
this way the bracing acts like 1 unit instead of 6 bracing points
yes, predrill every screw hole.
now that i see your design, yes i would brace that. or just do a double baffle.
W/ those subs and that sized enclosure you won't need any significant bracing. Just predrill, double baffle, and a small dowel right above the port would be more than sufficient. With the face having all 4 woofers + the port being the main reason why a lil bracing would help you out.
1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN.
Pioneer AVIC-N2
(12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each
Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s
26ft3 @ 33hz w/ a ton of port area
156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
