So if you look at my sig, Crump and I figured out that I only have a 17" trunk opening in my maxima, which is not big enough to fit 1 15" BTL, so does anyone have any input on doing 2 12" Audioque HD3s in a 4 cube box with the sundown saz 2000?
Edited by OrenB217
Black 1998 Nissan Maxima
1st Setup: 145.8 DB Outlaw @37 HZ On Music Out Of Trunk
2nd Setup: 147.8 DB @42 HZ On Music Out The Trunk
Current Trunk Build:
153.8 DB Outlaw @ 49 HZ Out the trunk (150.8 DB Sealed)
Team gg.
With that power and space I'd run 2 10s or 12s that require small amounts of airspace that will be more efficient w/ that power. Something like 2 FI SSDs, AB XFLs or IA Death Rows.
Pioneer AVIC-N2
I don't see why 17" is not enough for a 15" woofer. The boxes I put 15's in usually have less on the face then 17". I usually try to put a 15" woofer in a box that is 16-16.5" on the face where the sub is mounted. If it were me I'd make that 15 fit.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Well for me its 17"-1.5" (Mdf Top and bottem plate)=15.5 Outer ring of sub = 15.625" And there wouldnt be that much space between the baffles and the top and bottem plate, like less than an inch on top and bottem of the sub, so i dont think it would be that strong?
I've used 16" exactly for single 15s before without any issues at all, just brace it sum inside and you'll be just fine. 17" is plenty for a single 15, don't know why I didn't pick that up in ur first post.
Pioneer AVIC-N2
I dont like there only being about 1/4"-1/2" between the circle and the top and bottem plate, I just dont see that as being too strong. Especially with 2k+ watts and a btl. And this wasnt even the box plan I had with 17", with 17" I came up with a little more than 3 cubes. And I'm pretty sure he doesnt want that.
hoping to get around 4, so im slowly giving up on the 1 15
Team gg.
W/ 16" tall enclosure we ran a 15" AQ HD3(old version) off 4k daily with zero issues at all. We did a double baffle and sum bracing but no issues at all where the subs were mounted. It works just fine and that is from real experience, not someone who is just "guessing" at it like so many do on here. Something like a 15" DC LVL4 would be perfect off that amount of power in a smaller enclosure like you'd have. With more space it might have sum issues handling that power daily, but in an inefficient enclosure like you'd be running it would work just fine.
Pioneer AVIC-N2
Ok, so the height is good now, but with the bracing I still get 3.14 cubes (which he doesnt want)
But for 2 12's I get 3.81 cubes w/ 16.5 inches of height with everything i need for a good box. He wants input on aq not weather or not the box will work.
Edited by Crump
