So I'm pretty new to the car audio "scene"(haha) and was wondering if underpowering damages your sub?
Was lookin at 2 alpine type x 12's and was wondering how much rms in an amp would be recommended for them
Thanks in advance for info
I dont think that will damage your sub as a matter of fact I think that underpowering a sub will allow it to last longer. As long as the amp is in good condition. A bad amp makes a bad sub.
nah underpowering wont hurt subs,unless you decide to max your gains because its not load enoufgh..
RE se xxx 18d2 (4)
Audioque 2200 (2)
DC Power 270XP blue
3 C&D fr310
Stinger wiring
CDT components
no, underpowering your subs doesnt damage them. What do u think happens when you turn down the volume :D
a sub is blown either from mechanical or thermal failure. Failure shouldnt happen at RMS...even if clipping.
Eclipse cd7000
The reason why you hear stories of people blowing there say 1000rms sub off of a 400rms amp is they end up trying to get more output from there amp than it is capable of, by turning the gains and bass boost all the way up, as well as all the settings on the deck maxed out, and what they end up doing is sending a big ol square clipped signal to the sub, which ends up damaging the sub.
Someone correct me if I am wrong please.
Edit: To finkster, Wouldnt a clipped signal cause your coils to heat up, more than normal? And this would cause you coil to possibly fail.
Edited by CaptainzPlanetz
¿ǝɯɐƃ ǝɥʇ
if you try and push the amp to far and clip it may damage the woofer on less power, but a clean signal at or below RMS should not damage the woofer in a controlled environment. If the sub would "blow" with to little power it would smoke every time you turned the music down. :D
-Drew
uhoh_45 said:
It happens like this;
1) Click search
2) Enter desired search, "Underpowering Speakers" or "Underpowering Subs" etc
3) Select relevant thread
4) ?????????
5) PROFIT
Cheers,
Mick
Work;
DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS Venice
Meyer Sound CQ-1's, CQ-2's, PSW-2's
RAMSA Monitor Amplifiers
P.Audio Monitors
BSS OMNIDRIVE and Soundweb
DBX 231 and Klark Teknik DN360 EQ's
RCF TT22A
RCF ART320
