New Suburban Build. Ground Pounder (Engineering stage)
Do you know anyone who designs 6th orders cause IDK abut that box staying flat from 20-40hz? The only design that looks like it does well at those frequencies is a bandpass whether 4th order or 6th. I know you said you were set on the plans but 15-12's in a 6th order tunnel would be amazing!!!!
Rear chamber- 30cu.ft tuned to 25hz, Front chamber- 20cu.ft tuned to 60hz
I know you've done alot of high number systems with your box design already but do you think the frequency response will be flat from 20-45hz?
I would look at a few tunnel designs as they seem to yield better low end results when tuned right.
Here's a link to a build with 10- 12'' low end JBL's and 6000 watts.
10- 12'' JBL's 6000 rms tunnel
Here are his scores, pretty impressive to say the least.
Peak= 154.2dB @ 25hz
40hz= 150.3dB
33hz= 153.2dB
25hz= 154.2dB
20hz= 152.0dB
Drew
Ref's include: sundownz, army-killa, queball, wildsebring, foshay1123, greenman100, loud-n-low, acex3a, circa40, orangeless, PBateman,xtcxyooj, chaunb3400, oldschoolboomer, SPLluminator
What ever happened to that 1200 amp alt? Why don't you use that?
Drew
This is gonna be badass!!!
98 Toyota Camry
Eclipse AVN-6600
AudioControl 3.1
AudioControl Epicenter
US Amps AX2000
US Amps MD-43
1 set Alpine type X components
1 set RF Power components
1 12" RE Audio XXX
220 Amp Iraggi Alt.
Red Top (Front)
Kinetic HC-600 (Back)
Second Skin Damplifier Pro
Did you ever look into those tunnel designs, they are extremely efficient and straight sick on the low end.
What did your previous clamshells peak at?
Drew
I'll be watchin this for sure. dom i need a price quote for my 99 suburban 5.7 will be running at most 2000w on audio. heh for now atleast.
99 suburban
20" boss motorsport wheels
big 3 installed (thanks Iraggi)
alpine 9886 deck
kenwood 11 band eq
fosgate t5002 amp running sub
kenwood ps200 amp running components
jl xr components in front doors
jl xr 6.5 in rear doors
jl in rear roof
1 FI Q 18" with bp
enclosure 8 cubes 138 sq" port 34hz
Iraggi 220 ho alt
(RF 1500bd coming soon)
