I have no experience with the new version, with the updated mid and cross-over but I was extremely disappointed in the old version. The crossovers did not last, they were very poorly made. The tweeters (which as the same in the new version) are extremely harsh. This is in no way to put down DD because they make awesome subs and amps.
i believe bangin caddy has and likes them, maybe ask him about them. i had a set of them didnt like them much myself, but who knows maybe my install sucked
same as everyone else ^^^ the tweeters were harsh
R.I.P!
(Nov-29-2009)
92 explorer
current build
Harsh tweet as everyone above says. Attenuate it unless you like screaming highs. New crossover is WORLDS better than the old one. Get pretty loud but set your high pass filter wisely, they don't like the low lows (below 80-100hz kinda thing)
10.x volts fo' life!
