FU glass
:lol:
Exactly!
i thought "bullet proof glass" was lexan :pardon: ?
i have a website that has up to 5" plexi if ur interested...
Bulletproof glass consists of polycarbonate layers or other materials that are similar but it still has glass layers to it (the glass layers will crack spider if impacted just like regular glass would) so it would not really do me any good. Plexiglass is much weaker then lexan so lexan would be my best option if the new glass does not hold.
Caprice Wagon build
2010 Florida Spring Break Nationals MECA Drive By Winner
161DB on 15K @ 41hz
Eclipse Build
155+ No Wall
2007 Steel Valley Regionals 3X 139.9 Winner
2008 SoundXtreme 3X 149.9 Winner
2008 Slamology 149.9 3X Winner
2008 149.9 Bass Race World Champion
2009 149.9 Florida Spring Break Nationals Champion
  • 3 weeks later...
Finally got this thing to a meter on a location where the cops don't get called
(or where I don't get put in any newspapers :) )
Did some testing tonight on a single saz4500D
test 1
test 2
155DB legal
4500D @ .7 nominal
4469 watts
2.7 ohms(rise)
over a 153 down to 28hz
155.8 drivers window down
156 outlaw (drivers door open)
153.2 both front doors wide open
Caprice Wagon build
161DB on 15K @ 41hz
Eclipse Build
155+ No Wall
test 2
SICK!!
EDIT:
my tuning in my 4th order is now 27 hz .... pretty sure thats bad :lol:
EDIT 2:
how is the glass holding up? and i see everything got fixed from the situation you had?
EDIT 3:
gopnna be at slamology this year?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
damn good scores with one amp :)
what frequency you playing with?
Thanks, I am just getting started. I have not flared anything at the mouth of the enclosure yet and there are some things that should still be strengthened more.
36-44hz stays within a 3/10ths range of that score right now.
The freq in the test videos was 39 and 40hz
SICK!!
EDIT:
EDIT 2:
EDIT 3:
Thanks
27hz? in a 4th order? Are you saying that is the tuning of the ported chamber or what your hitting the dash at? If you have to tune that low for score in a 4th order your sealed chamber needs to shrink a good amount regardless. The ported chamber should be tuned higher then your loudest frequency (are you sure you calculated it correctly?). Slamology might happen depending on my work schedule.
Caprice Wagon build
161DB on 15K @ 41hz
Eclipse Build
155+ No Wall
Thanks
prett sure it was calculated correctly. maybe you can check the math for me? its ugh 16 or so cubes on the ported side, with 300 square inches port, 12 inches long. sealed is 4 cubes ... 2 18s
imma shorten te length and see what happens. still testing different things. i peaker @ 45 hz iirc. so i should tune 45 hz and up?
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
Thats a little more towards 66hz with about 33 hz bandwidth
