I like Singer! So when you and the old lady are fighting you can just throw a pillow and blanket in the tunnel and sleep there :D Is there any actual reason you didn't take the sealed enclosures to a V instead of leaving part of the back wall exposed? It kind of reminds me of Mick's 4th order without the loading wall and coming to a point in the rear. Any plans for a loading wall? I know I remember you telling me on the phone that with it wide open it wasn't quite going to be tuned where you wanted, but I don't remember if you said anything about a loading wall. Also where the hell are the batteries and amps at?????
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
have you ever noticed how you just do things... right?
i never see you make a mistake.
its like you set a goal and bam you get it first try
its badass
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Wow a Caprice SS wagon, those are very rare. That is a very nice setup.
2000 VW Jetta
Pioneer headunit
1 Soundstream PC.6 6.5" component set
4 Pioneer TSA6984R 6x9
4 Selenium 6w4p 6"
2 15" Sundown Audio E's in 4 cubes @35hz
Digital Designs CM1000
Rockford Fosgate Punch p400.4
Plans
New Box
New headunit
New Amps
R.I.P.1995 Chevy Blazer LS
Rockford Fosgate headunit
2 Rockford Fosgate T1 6.5"
2 Rockford Fosgate T1 4x6
2 Rockford Fosgate T1 4"
Hifonics Warrior hcx5.2c
4 Selenium 6w4p 6"
18" Mmats Juggernaut in 4.5 cubes @ 27hz
Hifonics Brutus 1200
Alpine 4 channel
Optima Red Top
Plans
New Box
New headunit
New Amps
Thanks Zach
The size of the woofers and vehicle limited what I could do with them in terms of placement and functionality. It is way different from Steves build though, center port, different angle on my V, different airspace on the sealed size in proportion to cone area, and a way different vehicle. The general platform of the build is the same I guess you could say, but I learned quite a bit more about 4th and 6th orders as Micks build and the A teams build evolved this season. There is two layers of 2x4s going around with steel plating against them now tuning it to 48hz (almost 10hz above my loudest frequency)
If the wagon likes the change in port area with tuning then it should only get louder. The ported chamber is around 21 square inches per cubic foot and each driver is in around 2.5-2.7 (around 5 cubes in each common chamber) I am guessing sealing it off and tuning it should be worth anything from .7-2.5db depending on what the vehicle wants.
The batteries are in the backseat in a 10"-52" enclosure I made that supports the enclosure and there is plenty of room on the sides for amps.
Yeah this at SBN is gonna be stupid loud.
LOVING the build so far.
Looking great bro.
I cant wait to sit in this if you have it done in a month.
Thanks Jacob
Thilo gets back in a week and a half then I will get the new 4Hps rolling for you.
I was able to internally regulate your alternator for 16 volts like the wagon (will charge at 19.1) so you don't have to worry about that horrible ext. reg everyone uses that can fail at any time! :)
its badass
Haha thanks man
I wish that was the case...I have problems or certain things don't work so I bust my ass or learn until they do.
Ask Meade, he is human too just like the rest of us :)
Caprice Wagon build
2010 Florida Spring Break Nationals MECA Drive By Winner
161DB on 15K @ 41hz
Eclipse Build
155+ No Wall
2007 Steel Valley Regionals 3X 139.9 Winner
2008 SoundXtreme 3X 149.9 Winner
2008 Slamology 149.9 3X Winner
2008 149.9 Bass Race World Champion
2009 149.9 Florida Spring Break Nationals Champion
nice Mike once you get it dialed in and add more power it should be pretty nuts cant wait to see it at SBN
thanks Nick I am doing my best to get all the batteries before then
but I am def planning the trip.
Planning on having this at SBN this year??
For sure
Caprice Wagon build
161DB on 15K @ 41hz
Eclipse Build
155+ No Wall
