I might be an idiot for asking this but how does the sub get excursion from that if its just getting constant power?
Power Acoustik fubar 12
sony xploding amp
2 ft^3 box @ 35hz
you just said it. its getting constant power.
Yeah but I thought that what made it go back and forth was the current switching back and forth or some shit...whatever, if it works it works.
sony xploding amp
2 ft^3 box @ 35hz
A speaker audio signal is just an AC current put through it at a certain wattage voltage and wavelength. When you plug it into a wall outlet, you will get an AC signal at 60hz but 15amps and 110 voltsRMS. MOST subs cannot handle this type of power for more than a minute at max because it's the equivalent of thousands and thousands of watts, plus at a higher voltage than the sub can handle so the coil short curcuits.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
