The Whole idea of this thread was to have the cheapest bang for buck street beater .
the car
i went with 4 starsound 15inch SVC woofers around $90 x 4
i did my measurements and went with fibreboard . yes fibreboard - very cheap about $40 for a 2.8m x 1.8 sheet
the box size was calculated at 10 cu ft
partly built
test fit in the car . nothing bigger will fit in there
tuned to 34hz - although i think the port might be too small , anybody confirm on this?
bracing - 4 x 16mm rods around $2
dropped it in the car .
got me 2 runs of 4 awg
2 for the earth and 2 power
im sadly still running the stock battery up front with just a cap in the back .
the amp is a ice power that will probably do abour 2.5kw @ 1ohm
its loud , i would think of numbers around the 150 .
i will have it metered soon to confirm .
this is not a daily box , it goes in when i feel like shaking the block . way too heavy for a daily
any comments ?
Ive had people told me , that the box will explode , but its braced really well and its not going anywhere .
Good on you for fitting that thing in there. I only did 7 cubes in mine for that 18, and I know I am doing 145-150ish. It is rediculous. I will also find a meter soon to verify. I will have to search hard. Not too many audio shops in Japan. Nice ride and box though. If if works for you then that's all that matters right?
www.AlabamaDrift.com04 Silverado in the works
nice job. port looks a lil small maybe and id suggest on gettin a better electrical and maybe a better amp. but i dont know how much power those subs handle though.
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
looks real nice man, you know its good when it takes up 75% of the cab lol.
2 RF P215's
Rockford 1 farad digital cap
RF X6.c Amp
Alpine head unit
JBL GTO component door speakers and two way rear deck speakers
i dont think it will explode, you use MDF and those bracings, plus its ported, so the pressure isn't as much.
if its flexing you may want to double baffle it, or even add some fiberglass inside the box..
very VERY nice man!
06 SCION tC
