Decaf Posted November 4, 2009 Report Posted November 4, 2009 i loved that setup fritos! what a great use for a otherwise useless speaker less a recone
fritosaregood Posted November 4, 2009 Report Posted November 4, 2009 i loved that setup fritos!what a great use for a otherwise useless speaker less a recone The axis are suppose to be easier to recone, by just replacing the hole top assembly. so thats what i did.. lot more expensive too. haha ive gone green with subs and recycle them :-) edit. for the spl portion. ive got a termlab now. Ill see if i can meter the box tomorrow. i wonder if those 4 E8s will like about 1500 watts seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
mr.p Posted November 4, 2009 Report Posted November 4, 2009 well for one if you build a flat wall in a suv, and had 2 18's how the hell would you fit 4 18" passive radiators on the baffle? DCAUDIO BALLS DEEP
fritosaregood Posted November 4, 2009 Report Posted November 4, 2009 well for one if you build a flat wall in a suv, and had 2 18's how the hell would you fit 4 18" passive radiators on the baffle? Thats when youd need 2 18 radiators with twice the xmax of the subs. or would having a radiator with a stiff suspension help anything? would it affect tuning? seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
mr.p Posted November 4, 2009 Report Posted November 4, 2009 you add weight to the passive radiators to change their tuning. and im not sure on the Xmax question, i would think thats possible. DCAUDIO BALLS DEEP
mr.p Posted November 4, 2009 Report Posted November 4, 2009 im guessing there is calculations for the xmax, suspension, weight to calculate what your tuning the box to. DCAUDIO BALLS DEEP
fritosaregood Posted November 4, 2009 Report Posted November 4, 2009 you add weight to the passive radiators to change their tuning. and im not sure on the Xmax question, i would think thats possible. I know about adding mass to the cone to change tuning, but since a stiffer suspension is harder to move, could that act like added weight? it that setup i had with the 15 and the 4 8's the 15 has around double the xmax of the 8's and close to the same cone area, so double xmax worked for me seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
baggedon4s Posted November 4, 2009 Report Posted November 4, 2009 Ground zero had these in the late 90's. I always wondered how they worked 99 suburban, ranger rover headlights, SS front bumper,roll pan with frenched tag, 2nd row delete,glassed dash..audio to come whenever I figure out what I want.
fritosaregood Posted November 5, 2009 Report Posted November 5, 2009 So, for spl. I metered the setup today, i just threw it in my back seat firing forward. i adjusted the gain on my 2 1500s strapped to put out 800 at 4 ohms box is tuned to 30ish. peaked at 58hz sealed up in the kickpanel it did a 134.1 driver door open in the kickpanel did a 135.6 then tried to give 3000rms to the E8s. only gained a little over a db with the door open did a 136.8 seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
Drek75633 Posted November 5, 2009 Author Report Posted November 5, 2009 Wow. Thank you guys. I never thought that I would get this much feedback on this. 2004 Mustang 3 18s 6 crossfire bmf 1700s strapped @ .5 161.2 db Daily driver 159.4 @ 45 hz 158.7 @ 35 hz 154.4 @ 25 hz Team Hz Addiction http://www.youtube.com/Drek75633
