Something that I was thinking about earlier today. Say you've got the choice of running either two lower end subs vs one higher end sub (from different companies). All subs in question are the same size and run on the same amp. The two subs would be getting 300 watts each, the single sub would be getting 600 watts. Enclosure size would be optimal for each sub.
In this situation does cone area beat out power?
Dan
id think so yes.since more cone area would be more louder assuming that the box are optimal for both subs either dual and the single ones.
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
If the 2 subs are seeing 600 watts for the pair, they will be louder than the single sub with 600 watts.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
i explained this in another topic but basically it is physics.
loud=pressure=air movement
since two cones have more potential to move more air they are normally louder
but say this one sub can move twice as far as the two subs. in theory (if the cone area of each sub individually is the same) the they should be the same volume of air displaced.
generally speaking though the 2 subs off 600 will move (ex) 10mm whereas the one sub off 600 will do 15-16mm
so the two subs can move the cone area times the vertical displacement of air same for the single sub
random numbers for visualization
cone area of single sub is 6
so for the 2 subs the equation is 6*2*10=120
single sub 6*16=96
see how it moves a lot less air. there is the reason why it is quieter more often than not
*note* these arent the real formulas just a basic idea of how things work.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
My single NightShade 15" was 1.2db louder than my two cvr 15"s off the same power.
that happens a lot. my single 3512 is louder than my cvr 15's off same power
but that was mostly failure of box design on my part.
but when you look at those subs vs the cvr's there is a shit ton more potential of moving air correct?
im not saying it doesnt happen because it does.
but the normal cheaper way to do it is more low power subs
like for example i boght the cvr's because i didnt have money so i spent 280 on those. pretty loud
then i went and spent 4 somethin on this one sub and its just a bit louder.
a lot of variables to consider
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
with more cone could also mean more motor force as less power compression as you are spreading the power across more coils
DCAUDIO
BALLS DEEP
ive been thinking of somethin on the lines of this.
its my take on wats better for and spl setup over a groundpounder. tell me if it sounds right
for spl you just play one tone at the box tuning so there is very little excursion
for a groundpounder you want to move tons of air
so spl would be more geared toward having tons of cone area
and a groundpunder would be ok with less area but more xmax per sub (but the same could be done by adding cone area).
^^does that sound about right?
kind of on the same topic
  • Who's Online   0 Members, 0 Anonymous, 952 Guests (See full list)
