How much power are you running?? I also suggest going CRX style or subs + port back depending on power. Either one will work out pretty well for ya in that vehicle.
Are you just going for a louder daily box or a burp box??
Pioneer AVIC-N2
its going into an envoy, i hear from a lot of other owners that it is louder to have it subs up with port firing off the hatch.
i am using a mmats d2100.1, so about 1500 at 1 ohm. i pulled a 141.1 at the dash, but at the time the power supply was going out and i was only seeing 1050. i got the power supply fixed, then i was seeing 1450, since then ive done a 1/0 form #4 wire, and done a big 3 in #4, so im not exactly sure what im pulling, though music is dynamic ....
if anyone thinks that a crx style box isnt going to have enough "musicability" what other design should i try, that dosent involve loosing my rear window.
lol, no blurping. im going for daily loud, tuned really low.
thanks for all the interest guys.
Edited by Gavinvoy
CRX style will have plenty of musical ability, idk why you'd think otherwise... But i'd suggest something like 4ft3 @ 34hz w/ 60in^2 of port, subs up and port facing towards the rear. Btw a loud daily enclosure usually doesn't go hand in hand with tuned very low(like 28-32hz). For an overall daily enclosure which will cover the whole range of notes I'd suggest tuning from 33-37hz.
Pioneer AVIC-N2
ehhhhh... i dont know, i like hitting them low notes. going off the factory specs are at 28. anything bad happen if its tuned that low?
i dont really want to get louder, not that its a bad thing, i just never go full tilt while listening, unless there are some hot chicks :D or showing off to fellow audiophiles.
CRX designs not good for Envoys :)
2018 Db Drag Street Trunk World Champion 156.9
2017 NSPL Trunk World Champion World 158.8
2016 Db Drag Street Trunk World Champion 156.7
2015 Db Drag Street Trunk World Champion 155.7
2015 NSPL Trunk World Champion World 158.3
2014 IASCA IDBL Trunk/Pickup 3 World Champion 157.1
2014 NSPL Trunk World record holder World Champion 157.4
2014 DB Drag Street Trunk World Record holder 154.4
2013 NSPL Trunk 0-48 World record holder 153.8
2013 IASCA Advanced Trunk 1 World Champion 155.5
2013 IASCA Advanced Trunk 2 World record holder 155.4
2013 DB Dragracing Street Trunk World record holder 154.3
2013 DB Dragracing Street Trunk Spring Break Nationals Champion
2013 Spring Break Nationals Champion IASCA Advanced Trunk 1
2012 NSPL Trunk 0-1800w World Champion record holder 151.3 @ 1731w 2012 IASCA Trunk 2 World Champion record holder 156.1 2012 USAC Trunk 1000 + World Finalist 158.4 2012 DB Drag racing Street Trunk World Champion record holder 154.3 2012 NSPL Trunk 3600+ World Record 156.7 legal/sealed/dash 2011 USAC Trunk 1000+ World Record 159,4 2011 NSPL Trunk 3600+ World Champion 2011 NSPL Trunk World record 156.6 dash 159.6 kick 2009 25-48NW NSPL World Champion 2009 Db Drag US.Top Certified SPL .St C 158.7 2008 Db Drag US.Top Certified SPL .St C 158.4 2008 25-48NW NSPL World Champion 2007 U.S.Top Cert. Street A,B,and C 2007 NSPL 0-24NW World Champion 2006 Db Drag St A World finalist. 2006 NSPL 0-24NW World Champion 2005 Db Drag St A World Champion 2005 NSPL 0-24NW World Champion 2004 Db Drag St A World finalist 2004 Db Drag US.record 642 points 2003 Db Drag Points World Champion 2003 NSPL 30-60NW World Champion 2002 Db Drag SS1-2NW World finalist 2002 NSPL 30-60NW World Champion 2001 Db Drag St 1-2 World finalist http://www.facebook....erry.SPL.Brocks Back in 02 my girlfriend said I had to make a choice between her and my love for car audio ......I told that b-tch I've made harder decisions at the Coke machine.
hello all, not sure if this is the right place, but here goes
i wanna change it up a bit. i have 2x Treo SSi 12.44 in a 3.6 cf box @ 28 hertz. I wanna do a crx style box (with subs up and port forward).
sub here:
http://treoonline.com/infosheets/ssi_subwoofers.pdf
going into an '02 Envoy
box:
44" wide x 23" long (about) x 16" tall
double baffle, with flush mount
i dont want to go taller. and i dont know if i wanna go into aero port territory.
MAY03LT said i should check out SMD.
ALMOST A MEMBERS RANK KEEP POSTIN MAN
Car Owned:2000 Malibu
Stereo:Ken-wood kdc 2022
# Of woofers 4
Amp:Ken-wood
No capaciters
all woofers are 12"
Amp wattage 600 watts
(SMD) MALIBU CUSTOM AZUL TYPHOON ADDITION OR A.K.A___M.C.A.T.A
what a worthless post. being a newbie or member or advanced member does nothing anyways :01nocomment8so: :rolleyes:
ima get to some number crunching for you now ;)
  • Who's Online   1 Member, 0 Anonymous, 502 Guests (See full list)
