77-AUDIO Posted November 6, 2009 Report Posted November 6, 2009 I have a friend that has a Dodge Charger and the factory location for the battery is in the trunk. How do I go about doing the Big 3 or will it be more like the Big 2. 1. Alt to Battery POS with 2 fuses on in front and one in rear. 2. Battery Neg to Body Ground. But do I need to also go from 3. Battery Neg to Motor Remember the factory battery is already located in the trunk. PPI dbl dinDC Level 31.77cubes net tuned to 33htz.DC audio 2.0kCT Pro Audio 8" in front, 6.5 in rear
OrionStang Posted November 6, 2009 Report Posted November 6, 2009 You don't need batt neg to engine, you need engine to chassis. And yes alt to batt + and batt- to chassis. SMD Super Seller My Feedback Thread
abervintageman42 Posted November 6, 2009 Report Posted November 6, 2009 if you cant find the engine block ground just ground the mounting bracket for the alternator to the chassis, you will get the same results
