right and wrong...
if you have little to no voltage drop without the cap then it is fine to add one because you are helping the peaks but otherwise it is always wiser to run more batteries
yeah thats true but if you have voltage drops, once the cap reads below a certain voltage done they start pulling power from the amp? in my opinion its caps FTL no matter what
how exactly do you wire up batteries to ur system
im new 2 this stuff
take adequately sized power wire and connect it to your front battery positive and run it to your back battery with a fuse somewhere in between then for a more secure method take another wire and run it from your negative on the front battery to the negative on the back but grounding the back battery to the frame will be just fine if you don't have enough to do 2 runs
some people like them but I'm with you on that one
Wouldnt be thehoe92 without teh purple
well actually they are good for something.... ricer applications always seem to benefit from them somehow :rolleyes:
when doing multiple batteries just remember FUSE IT!!!
i highly recommend batts over caps...even if you do say Kinteik 600s or Powermaster D925s or S30LBS great batteries and 100 times better than a cap (literally) haha
any of you think ima be needing a alternator
ima be running a arc audio 2500cxl and a 6040cxl
4 15w0's jl audio of course
2 jl audio 12w3's sealed
soon to be 4 level 3 15's
blow through
all dc audio
Here are a few good companies for ya - Kinetik, XS Power, Northstar, Hawker, etc.
Pioneer AVIC-N2
dont waste your money one them little 1farad caps........get an extra battery......
SWAT TEAM
TIM DOUGHERTY
09 USACI FINALS WORLD CHAMP TRUNK UNLIMITED 156.5db.....(157.6 in the bay but dont count cuz not recorded)
07 usaci finals 1801-3k 2nd
08 usaci finals 1801-3k 2nd
3X record holder-
USACi Stock 3K+ 155.1 legal
USACi Stock 1801-3k 156.9 legal
USACi Stock 1801-3k 160.9 OUTLAW
or if your cheap get a deka intimidator battery it will do the job most the other batteries will at a fraction the cost
  • Who's Online   0 Members, 0 Anonymous, 729 Guests (See full list)
