How does everyone brace their boxes?
ive got some stuff im gonna post up soon of what i found out about bracing, but im wondering what everyone says first.
I use 1.25" dowel rod and fiberglass. You've got me curious.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
I like dowels between all sides and then bond them together in the center somewhere.
97 Maxima SE
Bunch of shit going in, check out the build
lol get your eat on
Only reason I don't use 2x4's is because of the airspace they take up
For some background on this. Im a mechanical engineering student at college. and year i had a statics and dynamics class followed by a mechanics of materials class. It basically taught be about how things are stress by forces and what works to stop stresses. One thing that was focus on are like and I beam the long skinny part of the I add a rigidness and also spaces the two top and bottom parts to a distance. that also add strength. The there are T beams which is just an I beam without a bottom. So i built a box a few months ago and used the t beam concept to brace my box.
pic of the box
i also added some dowel rods because the T beam concept would of had a disturbance on the air flow
So this semester in class we have a program called Solidworks that we can build 3D models in and now we are learning how to make the program do stress analysis. So i decided to see how good the Tbeam concept worked. How i did it was a flat peice 30 by 17 inches, with all edged fixes in space like it would be attached to a box, Then put a force on the entire piece. I did 4 separate test each with the same force.
the pics are just screenshots put in paint and saved.
first i did just a .75" thickness to base things off of
Then one of just doubling the thickness how some ppl do
The pictures look the same, but the max stress on the double thickness is 1/4 that of the single thickness.
Then i did a single 1 " dowel rod
The max in this was actually double that of doubling the thinkness
Then i did the Tbeam way.
This way looks to be alot better, but the numbers actually show that around the edges (green spots) its a little more than the double thick board, the across the face is much better
Edited by fritosaregood
Depending on the size of the enclosure it will either be dowels or all thread. Then of course 45s, glass, and a ton of resin.
Pioneer AVIC-N2
