ohm load
t-money
whats should i look to be careful for if i wanna run at .5 ohm? also is it ok to run daily? and im looking at a new amp but untill then is the rockford punch p1000.1bd .5 ohm stable?
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
? anyone
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
I wouldn't do it....It might go into protect, burn up, blow fuses....or all three....
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
ok so punch is no good at .5 ohm. what about aq-2200 or dc 2000.1 at .5 ohm? stable? good idea for daily?
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
I definitely wouldn't suggest running the RF amp @ .5ohm at all. What is it with everybody wanting to run amps below rated lately?? Regardless if the amp can take that ohm load or not, it will break the warranty(if there is one) and they will not like running that low. The manufacturer ratings are there for a reason.
Pioneer AVIC-N2
x2
just fork up the money for an amp that puts out the power at a higher ohm load. youll save money in fried amps. also remember that going down to .5ohm seriously effect the efficiency of the amp. so you would have 50% or less efficiency. this means you need a lot more electrical than normal. also gives you 20%+ more heat inside the amp so you have to look at some really good cooling options. it really is cheaper and easier to get the better amp.
f that noise. ill just run 2000+ watts at 1 ohm then
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
good man.
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
