ok so i have an AQ1200d on the way.. im still trying to decide on woofers... im thinking about running 3 dual 4ohm 10's to it... comes out roughly to .66ohm but i figure after impedance rise it will proble be closer to 1ohm... anyways ive heard of guys running the AQ2200d at .5ohm... but dont know if it would be ok with the 1200d..
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
Well I got the AQ1200D, but only 1 d2 sub, so I couldn't really test it for you, but..when I had my ZX300.1, which they said isn't .5 ohm stable, I wired it to .5 ohm and it never blew on me, but it would go into protect after like an hour or two at full tilt, so this may be same with the AQ, may not..not positive, but if you find out, let me know
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
Im pretty sure you can I have heard of people doing it before Basshead08 runs his at .5 i think its in his sig.
2012 silverado ext cab ltz
24" kmc rims
AudioQue 2200
Pioneer AppRadio
Alpine mrx f35 4 channel
Bose mids and highs
Iraggi Alt + stock alt in a DC power dual alternator kit
Yellowtop+stock under hood
0 gauge Knu wire
Big 3
4 gauge stinger (4 chan wiring)
3 DC 10'' LVL3 with LVL4 parts
Well according to the diagrams on the12volt, lowest I can wire it at is 1ohm load, which is how I have it wired now
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
I'm still very confused as to how running a Kicker ZX300.1 @ .5ohm is relavent in any way... Also did u really run an amp at full tilt @ .5ohm for 2 hours straight?? If so :01nocomment8so:
But to the OP - You should be just fine running it at @ .66ohm daily.. Just make sure to set your gains correctly, don't be stupid with volume knob, keep an eye on your voltage and make sure the amp doesn't get to hot.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 695 Guests (See full list)
