i have a 1993 geo prizm 1.6 liter. im trying make it a sleeper. but im trying find out what other kind of engines i can fit in my car with out cutting or welding the stock motor mounts and if so which engines could i fit with making adjustments to the motor mounts. oooor what i could do to the stock engine to make it faster.???
First and foremost good luck, because you're gonna need it as a base platform for a true sleeper. A good start would be to browse google + car domain for examples of other modified Prizms. Then search on youtube + streetfire for videos that may also show/tell about the mods done to the vehicles.
What other vehicles is this engine shared with, if any??
Pioneer AVIC-N2
toyota corollas share the same engines
what do u mean by base playform??
b18c5 turbo with about 11lbs of boost should do the trick :)
2003 Ford Crown Victoria P71
2 12" Kicker CVX's
Audiopipe AP15001d
Stinger SR80 Isolator with DieHard 1200CCA battery
Streetwires 0awg
Secondary - 1998 Ford Expedition XLT
  • 3 weeks later...
if thats ur car in ur avatar pic that ba bro props
95 Delta 88
10 inch fubar(2 MB Quart RWE-352 15" on way soon)
1500.1 crunch
kenwood KDC-MP642U
Jp Kustomz
Why not just rebuild the stock engine and put a turbo on it?
2017 Chevrolet Silverado LT CC - Will be running 2-3 DC Audion M3 8s, unsure of amp, Mechman 320 amp alt.
2005 Ford F150 - Bagged on 24s, fully shaved, raised bed floor.
