15" kicker l7 baffle
kicker website my friend
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
Building a box for two 15" kicker l7s.. what does the holes have to be cut to? i read 13 and 1/2".. is that right?
13-3/4"
"loud 'cause its clipped like a 7yr olds buzz cut" -Decaf
"unfortunately i'm still tuned high as Giraffe pussy" -Twistedchild420
hold on what year are the L7. The new one are bigger?
Alpine D900 head unit 7" flip out t.v
Kicker 6 1/2 components (front,rear)KS 6502
MB quart 3 1/2" in front A/C vent's (center channel)
DC Audio LVL 5 18" (pair) Custom ported box
Sundown 4500 at .5
Sundown 100.4
XS 3100 up front and a pair of XS 6500 in the rear.
1 17" Eiger Vision T.V
2 7" Eiger Vision T.V in Second row.
Dynomat Top to Bottom (foam in all halo beam's)
DC Eng Alt 260SP and a 400SP dual set up.
big 3
Sitting on 24"
If your neighbor don't complain it's not Loud!
So you best go fix your shit !!!!!!!!!!!!!!
13-3/4"
^^^according to Kicker^^^^
Choose Model:15"|12"|10"|8"
Model Solo-Baric L7 15
Size (IN.,CM) 15, 38.1
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 2000/1000
Sensitivity (dB 1w/1m) 89.4
Frequency Response (Hz) 18-100
Mounting Depth (IN.,CM) 8-11/16, 22.1
Mounting Cutout, Square (IN.,CM) 13-3/4, 34.9
Min Rec Sealed Box Volume (CU. FT., Liters) 1.5, 42.5
Max Rec Sealed Box Volume (CU. FT., Liters) 6.0, 169.9
Min Rec Vented Box Volume (CU. Ft., Liters)** 3.0, 85.0
Max Rec Vented Box Volume (CU. Ft., Liters)** 6.0, 169.9
Edited by JPM75
You know i appreciate everyones help.. but whys do people have to be so cocky and rude when answering questions.. i dont understand.. you'd think people would be glad to help someone else out.. everyones been in my shoes and coming up learning stuff.. but thanks for the help.. no offense to anyone
I don't really see how anyone has been rude in this thread at all.. If you're gonna let something as little as this bother you, then an internet forum might not be the right place for you.
The only reason it may have come off to you that way is because the info that you were asking about was literally right on the Kicker website if you looked. Most are glad to help someone out when they truly need it, but in your case it just seems like you were a little lazy to have not looked on Kicker's website for info bout a Kicker product. It's just usually the most basic place to start.
Btw if you need any box building tips or help just drop me a PM.
Pioneer AVIC-N2
  • Who's Online   0 Members, 0 Anonymous, 922 Guests (See full list)
