it can also effect them with to much port.
to much port will make the woofers almost act free air
its like an exhaust system on your car. to little will restrict and choke the motor
to big will eliminate all back pressure (not a good thing)
i have 30 inches of port per cube lol... it works fine in my application
121 inches of port.. four cubes
that is alot much to much for daily use. with les port you have more "control of the subs" which will improve the longevity. 12-16 per cube sounds about right, a few slot boxes i had were built a little more towards the spl side of life but daily and they were 17 cubes with 200 inches of port. my bow for 6 fifteens has less than that. 30 per cube sounds more like a "burp box" ratio to me.
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
Any square/rectagular port is considered a slot port.
not necessarily. it's only considered a slot port if it shares at least 1 box wall as part of the port wall to effectively add in 'end correction' of the port. if a port has 4 of its own walls, like steves, then it's technically not a slot port.
true.
its just a square port
true.
I do 18-20 sq per cube daily or spl but thats just me and if the sub has a good suspension it will handle the big port :hairtrick:
2003 F150 Crew Cab
Panasonic DVD Flip Out
4 9515F's Dual 2(i soft parts)
4 DD M3a's
350A singer alt
8 nsb 90's
1 Nsb 125
161.5 @ 46hz in the kick USACI
Street Beat 4 2nd place USACI WF
158.5 @ 39hz LEGAL ON DASH
160's on music in kick
On higher Fs, more SPL oriented subs I like to stay between 16-20sqin per cube and for more daily driver SQL I usually stick to 12-16sqin.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
