Ronin Posted November 25, 2009 Report Share Posted November 25, 2009 Can these be ran together? Link to comment Share on other sites More sharing options...
xXxOuTLaWxXx Posted November 25, 2009 Report Share Posted November 25, 2009 (edited) they are from around 2000-01 and i wouldn't suggest running that new sub with the others Edit: i actually think they are earlier than that even. more like 98-00 Edited November 25, 2009 by cstrokers "i'd rather die like a man than live like a coward" quoted from Tupac Link to comment Share on other sites More sharing options...
kl0wn Posted November 25, 2009 Report Share Posted November 25, 2009 Not sure about running that old of a model with that new of a model, I ran an 06 model with an 08 model no problems though. Not sure with this one though 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz Link to comment Share on other sites More sharing options...
Marlo Stanfield Posted November 25, 2009 Report Share Posted November 25, 2009 I would not recommend running them together by any means. The top pics if from the early 2000s and the bottom one I think was released in 07/08ish. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
xXxOuTLaWxXx Posted November 25, 2009 Report Share Posted November 25, 2009 yeah, those are the series 1 L7's. damn near 10yrs old "i'd rather die like a man than live like a coward" quoted from Tupac Link to comment Share on other sites More sharing options...
Ronin Posted November 25, 2009 Author Report Share Posted November 25, 2009 I would not recommend running them together by any means. The top pics if from the early 2000s and the bottom one I think was released in 07/08ish. Even if they are both 4 ohm? Are the specs. different? I'm trying to find the specs on the older ones,anyone know where i might find them? Link to comment Share on other sites More sharing options...
ISO Posted November 25, 2009 Report Share Posted November 25, 2009 The ones in the first pic are the 2nd series of L7 and were out in 2002,03. The 2nd pic is the 2006,07 model. I wouldn't run them off the same amp but at the same time I feel that those 2 models have more in common than any of them have with the 2008,09 model. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
ISO Posted November 25, 2009 Report Share Posted November 25, 2009 Even if they are both 4 ohm? Are the specs. different?I'm trying to find the specs on the older ones,anyone know where i might find them? You should be able to get the specs off the site under support. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
Gotloud555 Posted December 7, 2009 Report Share Posted December 7, 2009 Kicker.com Link to comment Share on other sites More sharing options...
