groundpounder2k2 Posted May 13, 2007 Author Report Posted May 13, 2007 Im also getting a wicked engine noise..out of ....Just the left door... Quote My MainMan,My lil Man,Dude,Bubb....My son Memphis @ 3years OldShow'em that car son..........
roscoe1129 Posted May 13, 2007 Report Posted May 13, 2007 would check to make sure none of your wires are running parrallel with any factory ones if your coming across a spot where they are make sure you run them across and tie them off so they stay in a + that should help... Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
groundpounder2k2 Posted May 13, 2007 Author Report Posted May 13, 2007 No eq,s,,, Goes as follows... Head unit..Panasonic Ghost.. RCA....sub signal goes out of the deck... into a remote volume knob...out of that into 1st of 3....1500s..out of amp 1 into amp 2 out of amp 2 into amp 3 rca front signal is split 3 ways.....1 -4 channel amp on the 6.5s in the doors and 1/2 of the other 4 channel is on the kicks... rear rca signal goes to the other half of the second 4 channel amp..on the 5.25s in the rear dash/////////// ... Quote My MainMan,My lil Man,Dude,Bubb....My son Memphis @ 3years OldShow'em that car son..........
roscoe1129 Posted May 13, 2007 Report Posted May 13, 2007 Try taking the remote sub knob out of the pic and see if that doesnt clean up/strengthen your bass signal and just use the non fader controls on the ghost. Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
groundpounder2k2 Posted May 13, 2007 Author Report Posted May 13, 2007 http://www.subwoofertools.com/forum/setgain.asp according to that..........my gains should be set @ 54.8 volts....on the 1500s they are all dead on 54.8 but the bass seams really ...well ..not enough......untill the volume is at damn near full tilt... I set the gains with a 50Hz note... Quote My MainMan,My lil Man,Dude,Bubb....My son Memphis @ 3years OldShow'em that car son..........
roscoe1129 Posted May 13, 2007 Report Posted May 13, 2007 what is your pre out voltage at the head unit, then at the point where it hooks up to the amp, do they match? When you find that then set your amps gains to match them. Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
groundpounder2k2 Posted May 13, 2007 Author Report Posted May 13, 2007 what is your pre out voltage at the head unit, then at the point where it hooks up to the amp, do they match? When you find that then set your amps gains to match them. ok...my next dumb question.....how do i check that... Quote My MainMan,My lil Man,Dude,Bubb....My son Memphis @ 3years OldShow'em that car son..........
sean 371 Posted May 13, 2007 Report Posted May 13, 2007 http://www.subwoofertools.com/forum/setgain.aspaccording to that..........my gains should be set @ 54.8 volts....on the 1500s they are all dead on 54.8 but the bass seams really ...well ..not enough......untill the volume is at damn near full tilt... I set the gains with a 50Hz note... i've always set my gains at 3/4 the volume. This way, if one song has a lower volume recording than another, I have enough room to turn it up. Try it that way and see what you think. Oh, I dunno if you turned your bass boost or bass eq back up or not, but try that too. Quote A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
sean 371 Posted May 13, 2007 Report Posted May 13, 2007 ok...my next dumb question.....how do i check that... if you happen to have saved the manual for the h/u, it will tell you in there. Quote A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
groundpounder2k2 Posted May 13, 2007 Author Report Posted May 13, 2007 if you happen to have saved the manual for the h/u, it will tell you in there. looking at it right now Quote My MainMan,My lil Man,Dude,Bubb....My son Memphis @ 3years OldShow'em that car son..........
