A Sixteen Year Olds '95 S10 Extended Cab.
Some Info:
Mids/Highs:
---Dash/Door/Pioneer
---Rear Panel/Memphis
Subs:
---10 Inch/Polk Audio EXII
-----http://www.polkaudio.com/downloads/manuals/car/EXIISubManual.pdf
---12 Inch/Kicker Comp
-----Size (IN.,CM) 12, 30.5
Impedance (OHMS) 4 or 8
Max Rec Amplifier Power (WATTS PEAK/RMS)* 300/150
Sensitivity (dB 1w/1m) 89.1
Frequency Response (Hz) 27-500
Mounting Depth (IN.,CM) 5-13/16, 14.8
Mounting Cutout (IN.,CM) 11-1/8, 28.3
Min Rec Sealed Box Volume (CU. FT., Liters) 1.25, 35.4
Max Rec Sealed Box Volume (CU. FT., Liters) 3.5, 99.1
Min Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6
Max Rec Vented Box Volume (CU. Ft., Liters)** 2.25, 63.7
Amp: Alpine V12 MRV-F353
Head Unit: Pioneer DEH-P4000UB
Box:
---Top [10 Inch Subs]/1.25 Cubic Feet.
---Bottom [12 Inch Subs]/2.25 Cubic Feet. [~38 Hz]
http://s733.photobucket.com/albums/ww338/B...?albumview=grid
http://s733.photobucket.com/albums/ww338/B...mview=slideshow
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
is this your first setup? if so i will go easy on you. :P
  • 3 weeks later...
This is my second my first was a Pioneer shallow series 12, because I had a regular cab S-10 and I had to be able to have the seat all the way back.
Stick around, theres alot more to learn. Welcome to the forum btw.
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
Why are there 2 different sets of woofers and a tiny port
He hasnt been on here long enough to know better. ;)
Systemless.
from what i read its made into like 2 chambers the 10's are sealed and 12's are ported
2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012drew.png
no. this is for converting dc to ac. useful if you want to run a blender inside your car.
Oh my goodness, someone actually read, and didn't just look at the pics.
It could be worse no matter what you don't like, I wish you could see the systems at my school...
Kids are dropping a grand and getting a head unit, subs, amp, and some wires....
basically, they ghetto rig there systems.
